Multi WAN (3+) PCC load-balance problems
Hi, I’m trying to setup my multi wan load balance with x86 system (tried with RB750 too but low bandwith). Configuration goes OK but my problem is that only 2 connections are working at the same time, or one it depends, but never more. I have 4x15MBit/s but for now I’m just testing with 3 of them. Providers on all of them are the same. Basicly WAN2 & 3 works and WAN1 doesn’t. Or just WAN1 works. When i disable #3 first 2 works and when all 3 are enabled sometimes just first works, sometimes, 1 and 2 but mainly 2 and 3. And bandwith is around 30MBit/s sometimes a little more but never 45+. To make story short, heres my config so that you can sugest what am I doing wrong…
set [ find default-name=ether5 ] name=Local
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
add name=dhcp_pool1 ranges=10.50.50.2-10.50.50.254
add address-pool=dhcp_pool1 disabled=no interface=Local lease-time=1w name=dhcp1
add address=10.50.50.1/24 interface=Local network=10.50.50.0
add address=10.60.60.2/24 interface=WAN1 network=10.60.60.0
add address=10.70.70.2/24 interface=WAN2 network=10.70.70.0
add address=10.80.80.2/24 interface=WAN3 network=10.80.80.0
add address=10.50.50.0/24 dns-server=8.8.8.8 gateway=10.50.50.1
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=WAN2_conn
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=WAN3_conn
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN3_conn new-routing-mark=to_WAN3
add chain=prerouting dst-address=10.60.60.0/24 in-interface=Local
add chain=prerouting dst-address=10.70.70.0/24 in-interface=Local
add chain=prerouting dst-address=10.80.80.0/24 in-interface=Local
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN1_conn per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN2_conn per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN3_conn per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=Local new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=WAN3_conn in-interface=Local new-routing-mark=to_WAN3
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add check-gateway=ping distance=1 gateway=10.60.60.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=10.70.70.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=10.80.80.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=10.70.70.1
add check-gateway=ping distance=3 gateway=10.80.80.1
After upgrading 6.15 I face the same problem. İt changes but always one of the wan interface stops traffic and waits. I will downgrade 6.10 and try again… did you try that?
I tried this on all versions and its the same…
Backup your router
delete all mangle rules
import the above
let me know… it might work!
/ip firewall mangle
add action=accept chain=prerouting disabled=no dst-address=10.60.60.0/24 in-interface=Local
add action=accept chain=prerouting disabled=no dst-address=10.70.70.0/24 in-interface=Local
add action=accept chain=prerouting disabled=no dst-address=10.80.80.0/24 in-interface=Local
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN3 new-connection-mark=WAN2_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local new-connection-mark=WAN3_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn disabled=no in-interface=Local new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn disabled=no in-interface=Local new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN3_conn disabled=no in-interface=Local new-routing-mark=to_WAN3 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn disabled=no new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn disabled=no new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn disabled=no new-routing-mark=to_WAN3 passthrough=yes
cheers
With this config only 1 works (if all enabled first one only works…), with my config I could at least mix 2 connections but not 3 and with this theres no balancing at all, just failover…
are all your wans are operational?
do you have any route blue?
