Hello!
I have read the forum and found several similar issues, but none of proposed solution works, I’ll go through details later.
Context:
3 WAN connections
wan#1 - primary connection - Starlink (no public IP)
wan#2 - secondary connection - 1 public ipv4 IP
wan#3 - secondary connection - 1 public ipv4 IP
1 IPSEC tunnel terminating in AWS over #2 - but it is not relevant.
I mainly use wan#2 and wan#3 as backup connections, or to expose services publicly - but some services requiring public IP allowlisting or low latency such as VoIP are also going through wan#2 or wan#3.
I am only using mangling in my setup, and not routing rules. It might be a little complex, but it works really well so far.
I want to connect to my router using Wireguard - hence - turn my RB5009 as a “WG server”. I want to leverage one of the 2 connections with a public IP. Lets say wan#3.
When I’m inspecting packets, handshake is correctly coming through wan#3. The router then replies to this handshake, but packet leaves the router with wan#1- which obviously does not work.
I then tried to put mangling rule to mark WG packets, and change the routing table - similar to my other setups - to use wan#3. This time, I can see packet leaving the router on wan#3 - but with source IP address of wan#1 - and as such, packets get source-natted - which would be okay if source-port would not be changed.
I’m familiar with packet flow but hitting my limits here!
Is there a clean (or dirty !) way to change/override the source IP and port for wireguard handshake ? I tried source-nating - but it did not work. I saw some solutions based on routing-rules, but correct me if I’m wrong, this cannot be used here since I will use Wireguard clients with dynamic and unpredictable IP addresses, and it is not able to define routing rules based on port?
I’m attaching my configuration - but appreciate it can be fairly complex.
# 2024-08-17 23:34:37 by RouterOS 7.15.3
# software id = B9CF-ZH4I
# model = RB5009UG+S+
# serial number = XXXX
add name=bridge1-mdns port-cost-mode=short
set [ find default-name=ether4 ] comment="Static Admin"
set [ find default-name=ether8 ] comment=Starlink
/interface veth
add address=192.168.254.1/24 gateway=192.168.254.254 gateway6="" name=veth1-mdns-container
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard-wgcli
add listen-port=13232 mtu=1420 name=wireguard-server
/interface vlan
add comment="Access Points" interface=bridge1-mdns name=vlan2 vlan-id=2
add comment=IoT interface=bridge1-mdns name=vlan3 vlan-id=3
add comment=CCTV interface=bridge1-mdns name=vlan4 vlan-id=4
add comment=Infra interface=bridge1-mdns name=vlan5 vlan-id=5
add comment="Video Portier" interface=bridge1-mdns name=vlan6 vlan-id=6
add comment=Secure interface=bridge1-mdns name=vlan10 vlan-id=10
add comment=Guests interface=bridge1-mdns name=vlan100 vlan-id=100
add comment="VL101 - Amazon VPN" interface=bridge1-mdns name=vlan101 vlan-id=101
add comment="Clients of this VLAN will go through Starlink" interface=bridge1-mdns name=vlan200 vlan-id=200
add comment="Clients of this VLAN will go through WAN#2" interface=bridge1-mdns name=vlan201 vlan-id=201
add interface=bridge1-mdns name=vlan666 vlan-id=666
add comment="Data Wan#2" interface=bridge1-mdns name=vlan901 vlan-id=901
add comment="Data Wan#3" interface=bridge1-mdns name=vlan902 vlan-id=902
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-server option
add code=43 name=unifi-local value=0x0104AC10053D
add code=119 force=yes name=search value=0x0c736f6f6e6f6f6e6f6e6f6e6f02636f02752700
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=3 enc-algorithm=aes-128
add dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=3 enc-algorithm=aes-128 lifetime=8h name=tunnel-2 nat-traversal=no
add dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=3 enc-algorithm=aes-128 lifetime=8h name=tunnel-1 nat-traversal=no
add dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=3 enc-algorithm=aes-128 lifetime=8h name=tunnel-1-NAT
/ip ipsec peer
add address=x.x.x.x/32 local-address=x.x.x.x name=aws-wimax--2-1 profile=tunnel-1-NAT
/ip ipsec proposal
add enc-algorithms=aes-128-cbc lifetime=1h name=ipsec-vpn-0269e1769bdbda139-0
add name=vlan10 ranges=172.16.10.100-172.16.10.200
add name=vlan3 ranges=172.16.3.3-172.16.3.200
add name=vlan5 ranges=172.16.5.3-172.16.5.200
add name=vlan100 ranges=172.16.100.100-172.16.100.200
add name=vlan2 ranges=172.16.2.10-172.16.2.200
add name=vlan6 ranges=172.16.6.2-172.16.6.100
add name=vlan201 ranges=172.16.201.10-172.16.201.20
add name=vlan200 ranges=172.16.200.10-172.16.200.20
add name=vlan4 ranges=172.16.4.10-172.16.4.200
add name=vlan101 ranges=172.16.101.10-172.16.101.200
add address-pool=vlan10 interface=vlan10 name=vlan10
add address-pool=vlan3 interface=vlan3 name=vlan3
add address-pool=vlan5 interface=vlan5 name=vlan5
add address-pool=vlan2 interface=vlan2 name=vlan2
add address-pool=vlan6 interface=vlan6 name=vlan6 server-address=172.16.6.1
add address-pool=vlan201 interface=vlan201 name=vlan201
add address-pool=vlan200 interface=vlan200 name=vlan200
add address-pool=vlan4 interface=vlan4 name=vlan4
add address-pool=vlan101 interface=vlan101 name=vlan101
add address-pool=vlan666 interface=vlan666 name=vlan666
/ip smb users
/routing pimsm instance
add disabled=no name=pimsm-instance1 vrf=main
/routing table
add disabled=no fib name=wimax-3
add disabled=no fib name=wimax-2
add disabled=no fib name=Aws
add disabled=no fib name=wgcli
/routing bgp template
add as=65000 disabled=no name=aws routing-table=main
/container
add entrypoint=/app/run.sh interface=veth1-mdns-container logging=yes start-on-boot=yes
add bridge=bridge1-mdns ingress-filtering=no interface=ether1 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge1-mdns ingress-filtering=no interface=veth1-mdns-container internal-path-cost=10 path-cost=10
set enabled=yes udp-timeout=10s
/ip settings
set rp-filter=loose
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=*A list=LAN
add comment=defconf interface=ether8 list=WAN
add interface=vlan902 list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=x.x.x.x endpoint-port=x interface=wireguard-wgcli name=peer3 public-key="xxxx"
add allowed-address=192.168.201.2/32 interface=wireguard-server name=peer5 public-key="xxxx"
add address=172.16.10.1/24 interface=vlan10 network=172.16.10.0
add address=172.16.2.1/24 interface=vlan2 network=172.16.2.0
add address=172.16.3.1/24 interface=vlan3 network=172.16.3.0
add address=172.16.5.1/24 interface=vlan5 network=172.16.5.0
add address=172.16.100.1/24 interface=vlan100 network=172.16.100.0
add address=192.168.100.254/24 comment="Starlink Admin Interface" interface=ether8 network=192.168.100.0
add address=192.168.254.1 interface=veth1-mdns-container network=192.168.254.1
add address=172.16.1.1/24 interface=ether1 network=172.16.1.0
add address=172.16.6.1/25 interface=vlan6 network=172.16.6.0
add address=x.x.x.x/24 comment="wimax Data -3" interface=vlan902 network=x.x.x.0
add address=192.168.88.1/24 comment="Static Admin" interface=ether4 network=192.168.88.0
add address=172.16.201.1/24 interface=vlan201 network=172.16.201.0
add address=172.16.200.1/24 interface=vlan200 network=172.16.200.0
add address=x.x.x.x/24 comment="wimax Data -2" interface=vlan901 network=x.x.x.0
add address=172.16.4.1/24 interface=vlan4 network=172.16.4.0
add address=172.16.101.1/24 comment="AWS IOT TESTING" interface=vlan101 network=172.16.101.0
add address=169.254.37.226/30 comment="AWS Tunnel 1" interface=ether8 network=169.254.37.224
add address=172.16.66.1/24 interface=vlan666 network=172.16.66.0
add address=10.69.44.197 interface=wireguard-wgcli network=10.69.44.197
add address=192.168.201.1 interface=wireguard-server network=192.168.201.1
/ip dhcp-client
add interface=ether8
add address=172.16.2.0/24 dhcp-option=unifi-local dns-server=172.16.2.1 gateway=172.16.2.1 netmask=24
add address=172.16.3.0/24 comment=IOT dns-server=172.16.3.1 gateway=172.16.3.1 netmask=24
add address=172.16.4.0/24 comment=CCTV dns-server=172.16.4.1 gateway=172.16.4.1 netmask=24
add address=172.16.5.0/24 comment=Infra dns-server=172.16.5.1 gateway=172.16.5.1 netmask=24
add address=172.16.6.0/24 dns-server=172.16.6.1 gateway=172.16.6.1 netmask=24
add address=172.16.10.0/24 comment="Clients Secure" dns-server=172.16.10.1 gateway=172.16.10.1 netmask=24
add address=172.16.66.0/24 dns-server=8.8.8.8 gateway=172.16.66.2 netmask=24
add address=172.16.101.0/24 comment="AWS IOT TESTING" dns-server=10.128.1.242,10.128.1.192 gateway=172.16.101.1 netmask=24
add address=172.16.200.0/24 comment="Starlink Clients" dns-server=172.16.200.1 gateway=172.16.200.1 netmask=24
add address=172.16.201.0/24 comment="wimax Clients -3" dns-server=172.16.201.1 gateway=172.16.201.1 netmask=24
set allow-remote-requests=yes
/ip firewall address-list
add address=172.16.101.0/24 list=aws-advertised-net
add action=accept chain=input dst-port=8291 in-interface=vlan901 protocol=tcp
add action=accept chain=input comment="allow wireguard" dst-port=13232 in-interface=vlan901 protocol=udp
add action=accept chain=input comment="Allow NTP on VL101" dst-port=123 in-interface=vlan101 protocol=udp
add action=accept chain=input comment="allow all trafic from VPN" in-interface=wireguard-server
add action=accept chain=forward comment="allow all trafic from VPN" in-interface=wireguard-server
add action=accept chain=forward comment="forward trafic to VPN" out-interface=wireguard-server
add action=accept chain=forward comment="Doorbell to Secure" dst-address=172.16.10.0/24 log=yes log-prefix="doorbell >> " src-address=172.16.6.0/24
add action=accept chain=forward comment="Secure to Doorbell" dst-address=172.16.6.0/24 log=yes log-prefix="doorbell >> " src-address=172.16.10.0/24
add action=drop chain=forward disabled=yes out-interface=ether8 src-address=172.16.5.10
add action=accept chain=input comment="IPSEC AWS" dst-port=500 protocol=udp src-address=52.16.22.9 src-port=500
add action=accept chain=input comment="IPSEC AWS" protocol=ipsec-esp src-address=52.16.22.9
add action=accept chain=forward comment="ALLOW FORWARD AWS IPSEC" ipsec-policy=in,ipsec
add action=accept chain=forward comment="ALLOW FORWARD AWS IPSEC" ipsec-policy=out,ipsec log=yes
add action=accept chain=input comment="defconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-mark=no-mark connection-state=established,related disabled=yes hw-offload=no
add action=accept chain=forward comment="allow internet access for VL101" in-interface=vlan101 out-interface=ether8
add action=accept chain=forward comment="allow other VLANs to talk to VL101" connection-state=established,related in-interface=vlan101
add action=drop chain=forward comment="Block from VLAN101 to the rest of home" in-interface=vlan101
add action=drop chain=input comment="Block from VLAN101 to the rest of home" in-interface=vlan101
add action=accept chain=input comment="Allow SSH on wimax -3" dst-port=22 in-interface=vlan901 protocol=tcp
add action=accept chain=input comment="Allow HTTPS on wimax -3" dst-port=8443 in-interface=vlan902 protocol=tcp
add action=accept chain=input comment="Allow HTTPS on wimax -2" dst-port=8443 in-interface=vlan901 protocol=tcp
add action=accept chain=forward comment="wimax -3 TCP/80" dst-port=80 in-interface=vlan902 protocol=tcp
add action=accept chain=forward comment="wimax -2 TCP/80" dst-port=80 in-interface=vlan901 protocol=tcp
add action=accept chain=forward comment="SSH wimax -2" dst-port=2222 in-interface=vlan901 protocol=tcp
add action=accept chain=forward comment="wimax -3 TCP/443" dst-port=443 in-interface=vlan902 protocol=tcp
add action=accept chain=forward comment="wimax -2 TCP/443" dst-port=443 in-interface=vlan901 protocol=tcp
add action=drop chain=input in-interface=vlan902 protocol=tcp
add action=drop chain=input in-interface=vlan901 protocol=tcp
add action=drop chain=input in-interface=vlan902 protocol=udp
add action=drop chain=input in-interface=vlan901 protocol=udp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=output log=yes out-interface=vlan901
add action=accept chain=forward dst-port=554 in-interface=vlan902 protocol=tcp
add action=accept chain=forward dst-port=8000 in-interface=vlan902 protocol=tcp
/ip firewall mangle
add action=mark-routing chain=output log=yes log-prefix=WG4 new-routing-mark=wimax-2 passthrough=yes protocol=udp src-port=13232
add action=mark-connection chain=output log=yes log-prefix=WG new-connection-mark=wireguardserver passthrough=yes protocol=udp src-port=13232
add action=mark-routing chain=output comment="Wiregard Server" connection-mark=wireguardserver log=yes log-prefix=WG2 new-routing-mark=wimax-2 passthrough=no
add action=mark-connection chain=prerouting comment="wgcli VPN" disabled=yes new-connection-mark=wgcli passthrough=yes src-address=172.16.10.169
add action=mark-routing chain=prerouting comment="wgcli VPN" connection-mark=wgcli new-routing-mark=wgcli passthrough=no
add action=mark-connection chain=prerouting comment="VM wimax" in-interface=vlan201 new-connection-mark=wimax--2 passthrough=yes
add action=mark-connection chain=prerouting comment="Route to AWS" connection-state="" dst-address=!172.16.0.0/16 log=yes log-prefix="aws >>" new-connection-mark=aws passthrough=yes src-address=172.16.101.0/24
add action=mark-connection chain=output comment="IPSEC through wimax to AWS" dst-address=52.16.22.9 dst-port=500,4500 new-connection-mark=wimax--2 passthrough=yes protocol=udp
add action=mark-connection chain=output comment="IPSEC through wimax to AWS" disabled=yes dst-address=52.19.132.11 dst-port=500,4500 new-connection-mark=wimax--2 passthrough=yes protocol=udp
add action=mark-connection chain=output comment="IPSEC through wimax to AWS" new-connection-mark=wimax--2 passthrough=yes protocol=ipsec-esp
add action=mark-connection chain=input comment="INPUT from wimax -3" dst-port=8443 in-interface=vlan902 new-connection-mark=wimax--3 passthrough=no protocol=tcp
add action=mark-connection chain=input comment="INPUT from wimax -2" dst-port=8443 in-interface=vlan901 new-connection-mark=wimax--2 passthrough=no protocol=tcp
add action=mark-routing chain=output comment="OUTPUT to wimax -3" connection-mark=wimax--3 new-routing-mark=wimax-3 passthrough=no
add action=mark-routing chain=output comment="OUTPUT to wimax -2 - " connection-mark=wimax--2 log=yes new-routing-mark=wimax-2 passthrough=no
add action=mark-connection chain=prerouting comment="Mark wimax--3 everything coming in on wimax -3" in-interface=vlan902 new-connection-mark=wimax--3 passthrough=no
add action=mark-connection chain=prerouting comment="" in-interface=vlan901 ipsec-policy=in,none new-connection-mark=wimax--2 passthrough=no
add action=mark-routing chain=prerouting comment="Route to -3 connections marked to wimax -3" connection-mark=wimax--3 new-routing-mark=wimax-3 passthrough=yes
add action=mark-routing chain=prerouting comment="Route to AWS connections marked AWS" connection-mark=aws new-routing-mark=Aws passthrough=yes
add action=mark-routing chain=prerouting comment="Route to wimax -2 connections marked with wimax--2" connection-mark=wimax--2 new-routing-mark=wimax-2 passthrough=yes
add action=src-nat chain=test comment="TEMPO / TEST" protocol=udp to-addresses=x.x.x.x to-ports=13232
add action=src-nat chain=srcnat connection-mark=wireguardserver log=yes log-prefix=SRCNATWG protocol=udp to-addresses=x.x.x.x to-ports=13232
add action=masquerade chain=srcnat connection-mark=wireguardserver disabled=yes log=yes log-prefix=WG3 protocol=udp to-addresses=x.x.x.x to-ports=13232
add action=src-nat chain=srcnat comment="NAT trafic from secure VLAN to AWS VPC" dst-address=10.128.0.0/24 src-address=172.16.10.0/24 to-addresses=172.16.101.1
add action=accept chain=srcnat comment="AWS NAT excemption" disabled=yes dst-address=169.254.37.225
add action=accept chain=srcnat comment="AWS NAT excemption" src-address=172.16.101.0/24
add action=accept chain=srcnat comment="AWS NAT excemption" disabled=yes dst-address=192.168.0.0/24 src-address=172.16.101.0/24
add action=accept chain=srcnat comment="AWS NAT excemption" disabled=yes dst-address=169.254.40.221 src-address=169.254.40.222
add action=masquerade chain=srcnat comment="Masquerade Starlink" out-interface=ether8
add action=masquerade chain=srcnat comment="Masquerade wgcli" out-interface=wireguard-wgcli
add action=masquerade chain=srcnat comment="Masquerade wimax -2" connection-mark=!wireguardserver out-interface=vlan901
add action=masquerade chain=srcnat disabled=yes out-interface=vlan902 to-addresses=x.x.x.x
add action=dst-nat chain=dstnat comment="HTTP/HTTPS from wimax -3 to Traefik" connection-mark=wimax--3 dst-port=80,443 in-interface=vlan902 protocol=tcp to-addresses=172.16.5.60
add action=dst-nat chain=dstnat comment="HTTP/HTTPS from wimax -2 to Traefik" connection-mark=wimax--2 dst-port=80,443 in-interface=vlan901 protocol=tcp to-addresses=172.16.5.60
add action=dst-nat chain=dstnat comment="HTTP/HTTPS from wimax -2 to Traefik" connection-mark=wimax--2 dst-port=2222 in-interface=vlan901 protocol=tcp to-addresses=172.16.5.60 to-ports=22
add action=dst-nat chain=dstnat comment="Hairpin from VLAN10 (users-secure)" dst-address=x.x.x.x dst-port=80,443 in-interface=vlan10 protocol=tcp to-addresses=172.16.5.60
add action=dst-nat chain=dstnat comment="Hairpin from VLAN3 (iot)" dst-address=x.x.x.x dst-port=80,443 in-interface=vlan3 protocol=tcp to-addresses=172.16.5.60
add action=dst-nat chain=dstnat comment="Hairpin from VLAN5 (infra)" dst-address=x.x.x.x dst-port=80,443 in-interface=vlan5 protocol=tcp to-addresses=172.16.5.60
add action=dst-nat chain=dstnat connection-mark=wimax--3 dst-port=8000 in-interface=vlan902 protocol=tcp to-addresses=172.16.4.12
/ip ipsec identity
add peer=aws-wimax--2-1
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.0.0.0/8 peer=aws-wimax--2-1 proposal=ipsec-vpn-0269e1769bdbda139-0 src-address=172.16.101.0/24 tunnel=yes
add action=none dst-address=172.16.0.0/16 src-address=172.16.101.0/24
add dst-address=169.254.37.225/32 peer=aws-wimax--2-1 proposal=ipsec-vpn-0269e1769bdbda139-0 src-address=169.254.37.226/32 tunnel=yes
add dst-address=169.254.37.225/32 peer=aws-wimax--2-1 proposal=ipsec-vpn-0269e1769bdbda139-0 src-address=172.16.101.0/24 tunnel=yes
add disabled=no dst-address=0.0.0.0/0 gateway=x.x.x.254 routing-table=wimax-3 suppress-hw-offload=no
add disabled=no dst-address=172.16.5.0/24 gateway=vlan5 routing-table=wimax-3 scope=10 suppress-hw-offload=no
add disabled=no dst-address=0.0.0.0/0 gateway=x.x.x.254 routing-table=wimax-2 suppress-hw-offload=no
add disabled=no distance=1 dst-address=172.16.5.0/24 gateway=vlan5 pref-src="" routing-table=wimax-2 scope=10 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=172.16.101.0/24 gateway=vlan101 pref-src="" routing-table=wimax-2 scope=10 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=172.16.10.0/24 gateway=vlan10 pref-src="" routing-table=wimax-2 scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=172.16.101.0/24 gateway=vlan101 pref-src="" routing-table=Aws scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=172.16.10.0/24 gateway=vlan10 routing-table=Aws suppress-hw-offload=no
add disabled=no dst-address=172.16.10.0/24 gateway=vlan10 routing-table=wgcli suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard-wgcli pref-src="" routing-table=wgcli scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=172.16.1.0/24 gateway=ether1 routing-table=wimax-2 suppress-hw-offload=no
add disabled=no dst-address=192.168.201.0/24 gateway=wireguard-server routing-table=wimax-2 suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8080
set www-ssl address=0.0.0.0/0 certificate=rb5009 disabled=no port=8443 tls-version=only-1.2
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set always-allow-password-login=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/routing bgp connection
add as=65000 disabled=no hold-time=30s keepalive-time=10s listen=yes local.address=169.254.37.226 .role=ebgp name=aws-vpn-tunnel-1 output.keep-sent-attributes=yes .network=aws-advertised-net remote.address=169.254.37.225/32 \
.as=64512 routing-table=Aws templates=aws
/routing pimsm interface-template
add disabled=no instance=pimsm-instance1 interfaces=vlan3,vlan10
/system clock
set time-zone-name=Europe/Paris
/system logging
add prefix=ipsec topics=ipsec
/system note
set show-at-login=no
/system ntp server
set enabled=yes use-local-clock=yes
/tool graphing interface
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=all filter-ip-protocol=udp filter-port=13232 memory-limit=1000KiB streaming-server=172.16.10.161
