I have this scenario
My isp relase pubblic ip on dhcp
I have 4 pubblic ip: ip1, ip2, ip3, ip4
hardware RB750 ros 5.14
I want use all pubblic ip for nat 1:1 and RB managment winbox
I have tried virtual eth and VLAN for use all pubblic ip in the same ethernet interface but don’t work … (only one dhcp client work on phisical port)
Then I used 4 eth port (WAN1..WAN4) one for pubblic ip and 1 port for lan (LAN) — This approach is correct ?
My real problem is that routerboard don’t route to the internet I think that is neccessary a nat roule but I didn’t this …
nat 1:1 and masquerading on subnet lan work perfectly
this is routers table and firewall nat config
add comment=Default_Route disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
[internet-gateway] scope=30 target-scope=10
I write this with a simple script, I use in dhcp client add default route … only for redundancy i don’t sure if is necessary ..?
ip route print detail
0 A S ;;; Default_Route
dst-address=0.0.0.0/0 gateway=10.210.192.1
gateway-status=10.210.192.1 reachable via WAN3 distance=1 scope=30
target-scope=10
1 DS dst-address=0.0.0.0/0 gateway=10.210.192.1
gateway-status=10.210.192.1 reachable via WAN3 distance=10 scope=30
target-scope=10 vrf-interface=WAN1
2 DS dst-address=0.0.0.0/0 gateway=10.210.192.1
gateway-status=10.210.192.1 reachable via WAN3 distance=20 scope=30
target-scope=10 vrf-interface=WAN2
3 DS dst-address=0.0.0.0/0 gateway=10.210.192.1
gateway-status=10.210.192.1 reachable via WAN3 distance=30 scope=30
target-scope=10 vrf-interface=WAN3
4 DS dst-address=0.0.0.0/0 gateway=10.210.192.1
gateway-status=10.210.192.1 reachable via WAN3 distance=40 scope=30
target-scope=10 vrf-interface=WAN4
5 ADC dst-address=10.210.192.0/18 pref-src=10.210.249.170
gateway=WAN2,WAN1,WAN3,WAN4
gateway-status=WAN2 reachable,WAN1 reachable,WAN3 reachable distance=0
scope=10
6 ADC dst-address=192.168.0.0/24 pref-src=192.168.0.1 gateway=LAN
gateway-status=LAN reachable distance=0 scope=10
This is my ip fire nat config, I work arround for RB icmp and Winbox but … the router board don’t route to internet … not ping out, no dns, no snt client, no VPN client, etc…
add action=dst-nat chain=dstnat comment=Mkt_icmp-WAN1 disabled=no dst-address=10.210.249.169 \
protocol=icmp to-addresses=192.168.0.1
add action=netmap chain=srcnat comment=Net-WAN1 disabled=no src-address=192.168.0.2 to-addresses=\
10.210.249.169
add action=dst-nat chain=dstnat comment=Dst1-WAN1 disabled=no dst-address=10.210.249.169 dst-port=\
0-8290 protocol=tcp to-addresses=192.168.0.2 to-ports=0-8290 ### this is the work arround for use winbox on the first pubblic ip ###
add action=dst-nat chain=dstnat comment=Dst2-WAN1 disabled=no dst-address=10.210.249.169 dst-port=\
8292-65535 protocol=tcp to-addresses=192.168.0.2 to-ports=8292-65535 ### this is the work arround for use winbox on the first pubblic ip ###
add action=src-nat chain=srcnat comment=Src-WAN1 disabled=no src-address=10.210.249.169 \
add action=netmap chain=srcnat comment=Net-WAN2 disabled=no src-address=192.168.0.3 to-addresses=\
10.210.249.170
add action=dst-nat chain=dstnat comment=Dst-WAN2 disabled=no dst-address=10.210.249.170 \
to-addresses=192.168.0.3
add action=src-nat chain=srcnat comment=Src-WAN2 disabled=no src-address=10.210.249.170 \
add action=netmap chain=srcnat comment=Net-WAN3 disabled=no src-address=192.168.0.4 to-addresses=\
10.210.249.171
add action=dst-nat chain=dstnat comment=Dst-WAN3 disabled=no dst-address=10.210.249.171 \
to-addresses=192.168.0.4
add action=src-nat chain=srcnat comment=Src-WAN3 disabled=no src-address=10.210.249.171 \
add action=netmap chain=srcnat comment=Net-WAN4 disabled=no src-address=192.168.0.5 to-addresses=\
10.210.249.172
add action=dst-nat chain=dstnat comment=Dst-WAN4 disabled=no dst-address=10.210.249.172 to-addresses=\
192.168.0.5
add action=src-nat chain=srcnat comment=Src-WAN4 disabled=no src-address=10.210.249.172 to-addresses=\
192.168.0.5
add action=masquerade chain=srcnat disabled=no src-address=192.168.0.0/24 #### this is for masquerade al client LAN behind at the 4 client nat 1:1 ###
### All ip fire nat are write dynamicaly with a script (my pubblic ip is dynamic no static) ###
other relevant config
add address=192.168.0.1/24 comment="LAN" disabled=no interface=LAN network=\
192.168.0.0
/ip dhcp-client
add add-default-route=yes default-route-distance=10 disabled=no interface=WAN1 use-peer-dns=yes
add add-default-route=yes default-route-distance=20 disabled=no interface=WAN2 use-peer-dns=yes
add add-default-route=yes default-route-distance=40 disabled=no interface=WAN4 use-peer-dns=yes
add add-default-route=yes default-route-distance=30 disabled=no interface=WAN3 use-peer-dns=yes
Please ALL any suggestions for the best configurations and solve the routing RB problem
Thanks to all for yours suggest
Senzatempo
