please give proper scrip for dual wan failover
# Dual WAN setup script
# Version: 1.0
# Nikolay Unguzov
# ProComp Express
# Usage:
# 1. Set static IP addresses on WAN interfaces
# 2. Set sript for DHCP/statc convertion for DHCP ISP (if needed)
# Variables
:local "Interface_ISP1" "01.ISP1";
:local "IP_ISP1" "3.3.3.3";
:local "GW_ISP1" "3.3.3.1";
:local "comment_NAT_src_ISP1" "ISP1 NAT";
:local "comment_route_mark_ISP1_GW" "ISP1 GW";
:local "comment_mangle_ISP1_Out_IP" "ISP1 Out IP";
:local "comment_mangle_ISP1" "ISP1"
:local "comment_route_WAN1" "WAN1";
:local "Interface_ISP2" "02.ISP2";
:local "IP_ISP2" "4.4.4.4";
:local "GW_ISP2" "4.4.4.1";
:local "commenct_NAT_src_ISP2" "ISP2 NAT";
:local "comment_route_mark_ISP2_GW" "ISP2 GW";
:local "comment_mangle_ISP2_Out_IP" "ISP2 Out IP";
:local "comment_mangle_ISP2" "ISP2"
:local "comment_route_WAN2" "WAN2";
# Firewall rules
# ISP1
/ip firewall mangle
add action=mark-connection chain=prerouting comment=$"comment_mangle_ISP1" \
connection-state=new in-interface=$"Interface_ISP1" \
new-connection-mark=from-ISP1 passthrough=yes
add action=mark-routing chain=prerouting comment=$"comment_mangle_ISP1" \
connection-mark=from-ISP1 new-routing-mark=to-ISP1 passthrough=yes
add action=mark-routing chain=output comment=$"comment_mangle_ISP1" \
add action=mark-routing chain=output comment=$"comment_mangle_ISP1_Out_IP" \
new-routing-mark=to-ISP1 passthrough=yes src-address=$"IP_ISP1"
# ISP2
/ip firewall mangle
add action=mark-connection chain=prerouting comment=$"comment_mangle_ISP2" \
connection-state=new in-interface=$"Interface_ISP2" \
new-connection-mark=from-ISP2 passthrough=yes
add action=mark-routing chain=prerouting comment=$"comment_mangle_ISP2" \
connection-mark=from-ISP2 new-routing-mark=to-ISP2 passthrough=yes
add action=mark-routing chain=output comment=$"comment_mangle_ISP2" \
add action=mark-routing chain=output comment=$"comment_mangle_ISP2_Out_IP" \
new-routing-mark=to-ISP2 passthrough=yes src-address=$"IP_ISP2"
# Example - one host to ISP 2
add action=mark-routing chain=prerouting comment="TEST - out to ISP2" \
disabled=yes new-routing-mark=to-ISP2 passthrough=yes src-address=192.168.240.6
# Routing tables
add distance=1 gateway=$"GW_ISP1" routing-mark=ISP1 comment=$"comment_route_mark_ISP1_GW"
add distance=1 gateway=$"GW_ISP2" routing-mark=ISP2 comment=$"comment_route_mark_ISP2_GW"
add distance=1 gateway=$"GW_ISP1" comment=$"comment_route_WAN1"
add distance=2 gateway=$"GW_ISP2" comment=$"comment_route_WAN2"
# Routing rules
/ip route rule
add src-address=$"IP_ISP1" table=ISP1 comment=$"comment_mangle_ISP1_Out_IP"
add src-address=$"IP_ISP2" table=ISP2 comment=$"comment_mangle_ISP2_Out_IP"
add dst-address=10.0.0.0/8 table=main
add dst-address=192.168.0.0/16 table=main
add dst-address=172.16.0.0/12 table=main
add routing-mark=to-ISP1 table=ISP1
add routing-mark=to-ISP2 table=ISP2
# NAT
add action=src-nat chain=srcnat comment=$"comment_NAT_src_ISP1" \
out-interface=$"Interface_ISP1" to-addresses=$"IP_ISP1"
add action=src-nat chain=srcnat comment=$"commenct_NAT_src_ISP2" \
out-interface=$"Interface_ISP2" to-addresses=$"IP_ISP2"
# Dual WAN Check Links
# Version: 1.2
# Nikolay Unguzov
# ProComp Express
# Name: check-links
# Usage:
# Create script check-links and scheduler
:local MainInterface "01.ISP1"
:local BackupInterface "02.ISP2"
:local AlertEmail ""
:local MainRouteComment "WAN1"
:local BackupRouteComment "WAN2"
:local PingCount 2
:local PingTargets {1.1.1.1; 8.8.8.8; 77.88.8.8; 217.69.139.202}
:local PingHost
:local MainInterfaceInetOk false
:local BackupInterfaceInetOk false
:local MainPings 0
:local BackupPings 0
foreach PingHost in=$PingTargets do={
:local res [/ping $PingHost count=$PingCount interface=$MainInterface]
:set MainPings ($MainPings + $res)
:delay 1
:local res [/ping $PingHost count=$PingCount interface=$BackupInterface]
:set BackupPings ($BackupPings + $res)
:delay 1
:set MainInterfaceInetOk ($MainPings >= 1)
:set BackupInterfaceInetOk ($BackupPings >= 1)
:put "MainInterfaceInetOk=$MainInterfaceInetOk"
:put "BackupInterfaceInetOk=$BackupInterfaceInetOk"
:local MainGWDistance [/ip route get [find comment=$"MainRouteComment"] distance]
:local BackupGWDistance [/ip route get [find comment=$"BackupRouteComment"] distance]
:put "MainGWDistance=$MainGWDistance"
:put "BackupGWDistance=$BackupGWDistance"
if ($MainInterfaceInetOk && ($MainGWDistance >= $BackupGWDistance)) do={
/ip route set [find comment=$"MainRouteComment"] distance=1
/ip route set [find comment=$"BackupRouteComment"] distance=2
# Clear VoIP connections
/ip firewall connection remove [ find dst-address ~ ".*:5060" ]
/ip firewall connection remove [ find src-address ~ ".*:5060" ]
:put "Switched to MAIN Internet connection"
/log info "Switched to MAIN Internet connection"
:if ( [ :len $AlertEmail ] = 0 ) do={
/tool e-mail send to="$AlertEmail" \
subject="$[/system identity get name]: Switched to MAIN Internet connection" \
body="$[/system identity get name] switched to MAIN Internet connection - $MainInterface"
if (!$MainInterfaceInetOk && $BackupInterfaceInetOk && ($MainGWDistance <= $BackupGWDistance)) do={
/ip route set [find comment=$"MainRouteComment"] distance=2
/ip route set [find comment=$"BackupRouteComment"] distance=1
:put "Switched to BACKUP Internet connection"
/log info "Switched to BACKUP Internet connection"
subject="$[/system identity get name]: Switched to BACKUP Internet connection" \
body="$[/system identity get name] switched to BACKUP Internet connection - $BackupInterface"
# Dual WAN Check Links Scheduler
/system scheduler \
add interval=1m name=check-links-schedule \
on-event=check-links \
start-date=jan/01/1970 \
start-time=00:00:00
