multi WAN NAT for different LANs
Hi could anybody please help me out on this?
I have a setup with RB1100, 2 WAN lines, both have 1 static IP by ethernet connection.
WAN1 has 50MB bandwidth and WAN2 has 70MB.
LAN side I have 3 LANs.
here is the requirement, LAN1 using WAN1, LAN2 and LAN3 using WAN2
let’s say
WAN1: 1.1.1.2/30 gw 1.1.1.1
WAN2: 2.1.1.2/30 gw 2.1.1.1
LAN1: 192.168.1.0/24
LAN2: 192.168.2.0/24
LAN3: 192.168.3.0/24
I knew the routing will only choose the nearest route. if I just put 3 LANs in NAT masquerade , it will all go out by WAN1.
What should I do to make the setup work. please help , a example will be very appreciated.
Regards
Mangle rules, mark connections and routes. Then route according to the routing marks. This should all be covered in an MTCNA course.
Another approach that you may want to consider is PCC load balancing. This would match each connection with a different WAN rather then breaking it up by internal subnets. You can probably achieve a more even distribution of traffic this way. This is however assuming you don’t need to associate specific internal computers with specific public ip addresses.
http://wiki.mikrotik.com/wiki/Manual:PCC
Joshaven Potter
http://joshaven.com
Sent from my iPhone using Tapatalk
You don’t have to complicate things, just mark routing will do the job for you.
Here’s the link: http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
I consider to nerdtron that in this case “Policy based Routing” in combination with VLANs
would do the job perfectly, in my eyes.
PBR at the both WAN interfaces and then
VLAN10 - 192.168.1.0/24
VLAN20 - 192.168.2.0/24
VLAN30 - 192.168.3.0/24
This would be in my eyes the best practice.
A vlan would give you layer 2 seporation but it wouldn’t help you sort traffic between upline providers. The bottom like is that you need a default route with a routing mark then you need to add a routing mark to all traffic that you want to use that route through a mangle rule. You could choose the mangle rule criteria based on vlan, subnet or per connection with PCC. I would still would probably do PCC load balancing because it is most likely the option that would give you the best ability to load balance until you have a nearly even distribution of traffic. If you wanted you could use a vlan and PCC.
