Hi all,
Hoping to get to the bottom of a problem with my PCC load balance using recursive routes, I have it set up as a 5x WAN load balancer which really well apart from 1 small issue which keeps coming up with some sites we supply connectivity too.
I am using mangle rules to in the prerouting/output/prerouting chain as per all of the guides I have seen, running rOS7, RB4011. Port 1-5 WANs and rest for LAN
VPNs do not always work, The issue must be return traffic as depending on the type some connect and then do not work, others such as Watchguard VPN app will not establish a connection at all, I confirmed the VPN’s all work by removing the LB out of the network and they connect and work as expected.
My network topo is
WAN 1-5 (not all always in use mainly use 2x) which I adjust the mangle pcc rules for each time.
NAT being handled on this LB for the network below
LAN out to another RB4011 acting as a network core to a wider network.
Below is the config I am using, any pointers what might be causing VPNs not to work would be amazing.
I have some additional mangle rules in there to force subnets to a certain WAN too. LAN2 is also on there but not used.
Thanks in advance for your help
add name="LAN 1"
add name="LAN 2"
add name=l2tp-bridge
add name=WAN
add name=dhcp_pool1 ranges=192.168.48.50-192.168.51.254
add name=dhcp_pool2 ranges=192.168.52.50-192.168.55.254
add address-pool=dhcp_pool1 interface="LAN 1" lease-time=1d name=dhcp1
add address-pool=dhcp_pool2 interface="LAN 2" lease-time=1d name=dhcp2
/port
set 0 name=serial0
set 1 name=serial1
/routing table
add disabled=no fib name=ISP1
add disabled=no fib name=ISP2
add disabled=no fib name=ISP3
add disabled=no fib name=ISP4
add disabled=no fib name=ISP5
add bridge="LAN 1" interface=ether10
add bridge="LAN 1" interface=ether9
add bridge="LAN 1" interface=ether8
add bridge="LAN 1" interface=ether6
add bridge="LAN 1" interface=ether7
add interface=ether1 list=WAN
add interface=ether2 list=WAN
add interface=ether3 list=WAN
add interface=ether4 list=WAN
add interface=ether5 list=WAN
add address=192.168.48.1/22 interface="LAN 1" network=192.168.48.0
add address=10.250.0.1 interface=l2tp-bridge network=10.250.0.1
add address=192.168.52.1/22 interface="LAN 2" network=192.168.52.0
/ip dhcp-client
add add-default-route=no interface=ether1 script=":if (\$bound=1) do={\r\
\n /ip/route/set [find where comment=\"ISP1\"] gateway=\$\"gateway-addr\
ess\"\r\
\n}\r\
\n\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP1_conn\"]\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP2_conn\"]\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP3_conn\"]\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP4_conn\"]\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP5_conn\"]\r\
\n" use-peer-dns=no use-peer-ntp=no
add add-default-route=no interface=ether2 script=":if (\$bound=1) do={\r\
\n /ip/route/set [find where comment=\"ISP2\"] gateway=\$\"gateway-addr\
ess\"\r\
\n}\r\
\n\r\
\n/ip/firewall/connection/remove [find connection-mark=\"ISP5_conn\"]" \
add add-default-route=no interface=ether3 script=":if (\$bound=1) do={\r\
\n /ip/route/set [find where comment=\"ISP3\"] gateway=\$\"gateway-addr\
ess\"\r\
\n}\r\
\n\r\
add add-default-route=no interface=ether4 script=":if (\$bound=1) do={\r\
\n /ip/route/set [find where comment=\"ISP4\"] gateway=\$\"gateway-addr\
ess\"\r\
\n}\r\
\n\r\
add add-default-route=no interface=ether5 script=":if (\$bound=1) do={\r\
\n /ip/route/set [find where comment=\"ISP5\"] gateway=\$\"gateway-addr\
ess\"\r\
\n}\r\
\n\r\
/ip dhcp-server lease
add address=192.168.50.252 client-id=1:c4:ad:34:55:65:22 mac-address=\
C4:AD:34:55:65:22 server=dhcp1
add address=192.168.48.0/22 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.48.1
add address=192.168.52.0/22 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.52.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=10.0.64.0/20 disabled=yes list=FORCE-WAN1
add address=10.0.48.0/20 list=FORCE-WAN1
add address=10.0.0.0/20 list=FORCE-WAN2
add address=10.0.15.253 disabled=yes list=FORCE-WAN3
add address=10.0.15.253 disabled=yes list=FORCE-WAN4
add address=10.0.15.253 disabled=yes list=FORCE-WAN5
add address=192.168.48.0/22 list=LAN1
add address=192.168.52.0/22 list=LAN2
add address=10.0.16.0/20 list=FORCE-WAN2
add address=10.0.32.0/20 list=FORCE-WAN2
add action=accept chain=input connection-mark=ISP1_conn disabled=yes \
in-interface="LAN 1" protocol=ipsec-esp
dst-port=500,1701,4500 in-interface="LAN 1" protocol=udp
add action=drop chain=input comment="Block LAN 2 from Accessing LAN 1" \
dst-address-list=LAN1 src-address-list=LAN2
/ip firewall mangle
add action=mark-connection chain=prerouting comment="FORCE WAN 1" \
connection-mark=no-mark connection-state=new in-interface="LAN 1" \
new-connection-mark=ISP1_conn passthrough=yes src-address-list=FORCE-WAN1
add action=mark-connection chain=prerouting comment="FORCE WAN 2" \
new-connection-mark=ISP2_conn passthrough=yes src-address-list=FORCE-WAN2
add action=mark-connection chain=prerouting comment="FORCE WAN 3" \
new-connection-mark=ISP3_conn passthrough=yes src-address-list=FORCE-WAN3
add action=mark-connection chain=prerouting comment="FORCE WAN 4" \
new-connection-mark=ISP4_conn passthrough=yes src-address-list=FORCE-WAN4
add action=mark-connection chain=prerouting comment="FORCE WAN 5" \
new-connection-mark=ISP5_conn passthrough=yes src-address-list=FORCE-WAN5
add action=mark-connection chain=prerouting connection-mark=no-mark \
connection-state=new in-interface=ether1 new-connection-mark=ISP1_conn \
passthrough=yes
connection-state=new in-interface=ether2 new-connection-mark=ISP2_conn \
passthrough=yes
connection-state=new in-interface=ether3 new-connection-mark=ISP3_conn \
passthrough=yes
connection-state=new in-interface=ether4 new-connection-mark=ISP4_conn \
passthrough=yes
connection-state=new in-interface=ether5 new-connection-mark=ISP5_conn \
passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn \
new-routing-mark=ISP1 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2_conn \
new-routing-mark=ISP2 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP3_conn \
new-routing-mark=ISP3 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP4_conn \
new-routing-mark=ISP4 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP5_conn \
new-routing-mark=ISP5 passthrough=yes
add action=mark-connection chain=prerouting comment="PCC on these - WAN1" \
connection-mark=no-mark dst-address-type=!local in-interface="LAN 1" \
new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=\
src-address-and-port:2/0
connection-mark=no-mark disabled=yes dst-address-type=!local \
in-interface="LAN 1" new-connection-mark=ISP1_conn passthrough=yes \
per-connection-classifier=src-address-and-port:3/1
add action=mark-connection chain=prerouting comment="PCC on these - WAN2" \
new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=\
src-address-and-port:2/1
dst-address-type=!local in-interface="LAN 1" new-connection-mark=\
ISP3_conn passthrough=yes per-connection-classifier=\
src-address-and-port:5/3
ISP4_conn passthrough=yes per-connection-classifier=\
src-address-and-port:5/4
ISP5_conn passthrough=yes per-connection-classifier=\
src-address-and-port:5/5
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
in-interface="LAN 1" new-routing-mark=ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
in-interface="LAN 1" new-routing-mark=ISP2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP3_conn \
in-interface="LAN 1" new-routing-mark=ISP3 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP4_conn \
in-interface="LAN 1" new-routing-mark=ISP4 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP5_conn \
in-interface="LAN 1" new-routing-mark=ISP5 passthrough=yes
add action=mark-routing chain=prerouting comment="test for vpn" \
connection-mark=ISP1_conn disabled=yes new-routing-mark=ISP1 passthrough=\
yes
add action=masquerade chain=srcnat comment=\
"NAT Rule when Using SRE CORE - Must Disable NAT MAS Rules on CORE" \
out-interface-list=WAN src-address=172.18.0.0/22
out-interface-list=WAN src-address=172.17.0.0/22
out-interface-list=WAN src-address=172.16.0.0/22
add action=masquerade chain=srcnat out-interface=ether2
add action=masquerade chain=srcnat out-interface=ether3
add action=masquerade chain=srcnat out-interface=ether4
add action=masquerade chain=srcnat out-interface=ether5
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
192.168.80.1 pref-src="" routing-table=ISP1 scope=30 suppress-hw-offload=\
no target-scope=10
192.168.1.1 pref-src="" routing-table=ISP2 scope=30 suppress-hw-offload=\
no target-scope=10
192.168.2.1 pref-src="" routing-table=ISP3 scope=30 suppress-hw-offload=\
no target-scope=10
192.168.80.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
no target-scope=10
add check-gateway=ping disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=\
192.168.1.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
no target-scope=10
add comment=ISP1 distance=1 dst-address=9.9.9.9/32 gateway=192.168.1.1 scope=\
10 target-scope=10
add comment=ISP2 distance=1 dst-address=8.26.56.26/32 gateway=192.168.88.1 \
scope=10 target-scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=9.9.9.9 \
scope=10 target-scope=11
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=8.26.56.26 \
add comment=ISP1 dst-address=64.6.64.6/32 gateway=192.168.1.1 scope=10
add comment=ISP1 dst-address=208.67.220.220/32 gateway=192.168.1.1 scope=10
add comment=ISP2 dst-address=208.67.222.222/32 gateway=192.168.88.1 scope=10
add comment=ISP2 dst-address=64.6.65.6/32 gateway=192.168.88.1 scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=64.6.64.6 \
routing-table=ISP1 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=64.6.65.6 \
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=\
208.67.222.222 routing-table=ISP2 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=\
208.67.220.220 routing-table=ISP2 scope=10 target-scope=11
add comment=ISP3 distance=1 dst-address=185.73.44.147/32 gateway=192.168.1.1 \
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=185.73.44.147 \
add comment=ISP3 dst-address=76.76.2.0/32 gateway=192.168.1.1 scope=10
add comment=ISP3 dst-address=76.76.10.0/32 gateway=192.168.1.1 scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=76.76.2.0 \
routing-table=ISP3 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=76.76.2.0 \
add comment=ISP4 distance=1 dst-address=185.228.168.9/32 gateway=192.168.80.1 \
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=185.228.168.9 \
add comment=ISP4 dst-address=185.228.169.9/32 gateway=192.168.80.1 scope=10
add comment=ISP4 dst-address=76.76.19.19/32 gateway=192.168.80.1 scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=185.228.169.9 \
routing-table=ISP4 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=76.76.19.19 \
add comment=ISP5 distance=1 dst-address=76.223.122.150/32 gateway=192.168.1.1 \
76.223.122.150 scope=10 target-scope=11
add comment=ISP5 dst-address=94.140.14.14/32 gateway=192.168.1.1 scope=10
add comment=ISP5 dst-address=94.140.15.15/32 gateway=192.168.1.1 scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=94.140.14.14 \
routing-table=ISP5 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=94.140.15.15 \
add comment="Route back to CORE Networks" disabled=no distance=1 dst-address=\
172.16.0.0/22 gateway=192.168.50.252 pref-src="" routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
172.17.0.0/16 gateway=192.168.50.252 pref-src="" routing-table=main \
10.0.0.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.16.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
172.18.0.0/16 gateway=192.168.50.252 pref-src="" routing-table=main \
10.0.32.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.48.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.64.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.80.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.96.0/20 gateway=192.168.50.252 pref-src="" routing-table=main scope=\
10.0.112.0/20 gateway=192.168.50.252 pref-src="" routing-table=main \
/routing rule
add action=lookup-only-in-table disabled=yes src-address=10.250.0.1/32 table=\
ISP5
