Multi-Wan setup from separate modem-routers
Introduction:
Hello everyone i am currently doing my first Structured Cabling , at home and i would like your opinions of what is the best approach to create a multi-wan setup using a Mikrotik router as a Centralized Management Router. So firstly i would like to give you an idea of how it is currently set up and what my end-goal is. I live in a country where we use VDSL2+ with vectoring and ISP routers use PPoE for authentication to get access to the internet. The cable itself is just 1 pair , one for sending and one for receiving and is connected using a RJ11 clip on the DSL port of each router. To reach my goal of a multi-wan setup i centralized everything on a rack. The Rack includes the following:
Gear:
  1. 2x ISP routers (Both have bridge mode & IP Passthrough functionality) - (Modem/Routers)
  2. 1x Patch Panel-24
  3. 1x Mikrotik CRS326-24G-2S+(Router & Switch, but no modem)
  4. 1x N5105 Fanless Mini-PC(4 port gigabit) (Proxmox-pfsense)
Goal:
What i want to achieve is a load-balanced multi-wan configuration on the Mikrotik Router with CAKE as the QOS for better packet management. The Fanless Mini-pc with proxmox installation and a pFsense virtual firewall to protect the devices behind while also serving services for automation etc.
My current order is: ISP β†’ R1/R2 β†’ Mikrotik β†’ Firewall β†’ Clients.
My ideal order is: ISP β†’ R1/R2 β†’ Firewall β†’ Mikrotik β†’ Clients.
Tell me your thoughts and guidance if i need to change something or what would be the optimal setup-order for it to work better. Thanks!
You might already start not using that crs326 as a router.
It's a switch.
It can do routing, yes, but it remains a switch at first.
Perhaps use the mini PC as router since you also plan to do firewall there ?
Concur you have a switch not really a capable router.
What is the throughput on each of your WAN connections??
If its acting solely as a switch looks good. If you expect the swtich to route and do the multi-wan, you got the wrong gear. Replace the mini-pc with an MT router ( ax3 for cheap, 5009 if you have the budget )
Choosing proper router is one problem but if it comes to configuration then please check many posts on "Multi WAN": Search results for 'multi wan setup' - MikroTik community forum
It will help you to understand basics.
Use the N5105 with pfSense as the router (pfSense has support for Multi-WAN), and use the MikroTik CRS as a switch. Don't expect the CRS to handle CAKE and QoS with high throughput (because no Hardware Offload and no Fasttrack would then be available).
The internet connections are not that high it’s like 100Mbps each
Since the available bandwidth is not that high is this gear not enough for 2x 100Mbps connections?
The only concern about this was that i trust Mikrotik more than the mini-pc in terms of hardware. So i wanted to have the ability to check what is going on the mini-pc first before i switch to the mini-pc as the first in line device.
If you don't use CAKE but something less CPU intensive, then the dual core 800MHz CPU would be enough for routing with NAT with your 2x100Mbps lines.
