I am a RouterOS newbie trying to setup automatic load balancing and automatic fail-over and port forwarding trough 2 ISPs connected to my router.
I know, load balancing/fail-over was discussed numerous times for different generations of RouterOS and using different approaches, I’ve read and implemented them all with various degree of success. To me, ECMP seems to be the most simple and robust way of implementing this. However, none of the approaches properly support/describe how to make (same) port forwarding work in such setups.
In the setup below, port forwarding through ISP1 and ISP2 works as expected, but if I change the distance on 0.0.0.0/0 → 192.168.2.1 route to 1, ECMP begin to work as expected, splitting connections roughly equally between both ISPs, however, the port forwarding through ISP1 stops working (but remains functional through ISP2).
/system resource print
uptime: 1d21h10m50s
version: 7.3.1 (stable)
build-time: Jun/09/2022 08:58:15
factory-software: 6.44
free-memory: 45.8MiB
total-memory: 128.0MiB
cpu: ARM
cpu-count: 4
cpu-frequency: 672MHz
cpu-load: 2%
free-hdd-space: 580.0KiB
total-hdd-space: 15.2MiB
write-sect-since-reboot: 32185
write-sect-total: 111282
bad-blocks: 0%
architecture-name: arm
board-name: hAP ac^2
platform: MikroTik
<br>
> ```text
add name=ilist-lan1
add name=ilist-wan1
add name=ilist-wan2
add include=ilist-lan1 name=ilist-lan
add include=ilist-wan1,ilist-wan2 name=ilist-wan
add interface=bridge1-lan1 list=ilist-lan1
add interface=ether1-wan1 list=ilist-wan1
add interface=ether2-wan2 list=ilist-wan2
add address=10.10.10.1/24 interface=bridge1-lan1 network=10.10.10.0
add address=192.168.1.2/24 interface=ether1-wan1 network=192.168.1.0
add address=192.168.2.2/24 interface=ether2-wan2 network=192.168.2.0
<br>
> ```text
/routing table
add fib name=rtab-ether1-wan1-only
add fib name=rtab-ether2-wan2-only
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-table=main distance=2
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=rtab-ether1-wan1-only
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-table=rtab-ether2-wan2-only
<br>
> ```text
/ip firewall address-list
add address=10.0.0.0/8 list=alist-lan
add address=192.168.1.2 list=alist-wan-mapped
add address=192.168.2.2 list=alist-wan-mapped
add address=10.0.0.0/8 list=alist-connected
add address=172.16.0.0/12 list=alist-connected
add address=192.168.0.0/16 list=alist-connected
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=ilist-wan src-address-list=alist-lan
add action=dst-nat chain=dstnat dst-address-list=alist-wan-mapped dst-port=443 in-interface-list=ilist-wan protocol=tcp to-addresses=10.10.10.10 to-ports=443
<br>
> ```text
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=alist-connected src-address-list=alist-connected
add action=mark-connection chain=input connection-mark=no-mark in-interface=ether1-wan1 new-connection-mark=cmark-ether1-wan1-to-router
add action=mark-connection chain=input connection-mark=no-mark in-interface=ether2-wan2 new-connection-mark=cmark-ether2-wan2-to-router
add action=mark-routing chain=output connection-mark=cmark-ether1-wan1-to-router new-routing-mark=rtab-ether1-wan1-only
add action=mark-routing chain=output connection-mark=cmark-ether2-wan2-to-router new-routing-mark=rtab-ether2-wan2-only
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ether1-wan1 new-connection-mark=cmark-ether1-wan1-to-lan passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ether2-wan2 new-connection-mark=cmark-ether2-wan2-to-lan passthrough=yes
add action=mark-routing chain=prerouting connection-mark=cmark-ether1-wan1-to-lan in-interface-list=ilist-lan new-routing-mark=rtab-ether1-wan1-only
add action=mark-routing chain=prerouting connection-mark=cmark-ether2-wan2-to-lan in-interface-list=ilist-lan new-routing-mark=rtab-ether2-wan2-only
