MultiAP on 3 atheroses
I want to set up the base station with 3 sectors in AP mode.
I want to use nstreme in all three ap.
So I configure 3 atheroses as sect1, sect2, sect3 on diffrent channels (5640, 5660, 5680) and turn on nstreme. One station connects to sect1, other to sect2. Pings between station1 and station2 are horrible (200-800ms) and station2 start to “flash” on AP. Signal on both 50-60 (lab testing). I switch station 1 do sect2 and station2 do sect3 - the same problem.
It looks like it is one global nstreme memory area and two or more nstreme realms not work well together.
When nstreme is off on atheroses, it works on 50%, i think.
Where is the problem?
Nstreme is still not stable to work in multi AP configuration?
When one atheros is in nstreme mode and 2 others are in native, there is no problem with “flashing”, but performance is not good.
Thanks for anserws…
Piotr
ok, thanks to marksx, I choose channels to close
Can you post more details how its working AP with 3 radio cards on it. What are results without NStreme. I was wondering if they will work without intefering with each other.
3 atheroses - channel separation 3 so: it’s working fine with 5500, 5560, 5620 for example.
and forth card - prism
all in one base, in lab work stable
with nstreme and 60Mbit of traffic on 3 cards (2 atheroses, 1 prism, all in AP mode) and 20-50% cpu on cel 2,6
60Mbit traffic on EACH of those three cards (total = 180Mbit/s) or on all three TOGETHER (total = 60Mbit/s) ?
60Mbits at all, on 2 atheroses and prism
Third atheros with no traffic. I must make another station to test it.
I have on stations P133 with atheros so bandwidth test take them 100% of CPU in second :wink:
At now I have not enough powerfull stations to make more traffic.
