Hey All,
After spending quite some time now working on multicast systems and setups that I want to trial I’ve hit a rather large brickwall that I’m having no luck with.
I have managed to get multicast working with a core MT router that has a VLC server connected and streaming to 232.0.0.1, I have attached a computer to another interface on the same router and got the Multicast stream to play. I then connected another MT router acting as an AP to the core MT router and connected off that AP and got the Multicast stream to play. I have then attached a MT CPE to this AP and attempted to play the Multicast stream which is where it fails.
I’m getting a error in the AP logs to do with PIM:
Join/Prune Entry for group 239.255.255.250 RP address does not match: router RP = 172.16.1.1 message RP = 172.16.3.1
This is a visio layout of my testing lab right now, I need to be able to have multiple AP routers attached to the core and have the CPE get multicast without having to vlan/layer2 the CPE back to the core. Does anyone have any ideas? I’m really quite stuck
