I have adjusted the mcs rates without multicast video improving to ht-basic-mcs=mcs-4,mcs-5,mcs-6,mcs-7,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-txchains=0,1 .
I am unsure if I should expect one or two chains to be active.
I have left multicast-helper=full because I can’t afford loosing packets in the video streaming.
Here is the bridge transmittings side :
[admin@MikroTik] /interface wireless> print advanced Flags: X - disabled, R - running
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:F2:44:1C arp=enabled disable-running-check=no
interface-type=Atheros 11N radio-name="000C42F2441C" mode=bridge ssid="radioaktive" area=""
frequency-mode=superchannel country=no_country_set antenna-gain=10 frequency=5260 band=5ghz-a/n
channel-width=20/40mhz-ht-above scan-list=default wireless-protocol=nv2 rate-set=configured
supported-rates-a/g=36Mbps,48Mbps,54Mbps basic-rates-a/g=36Mbps,48Mbps,54Mbps max-station-count=2007
distance=dynamic tx-power-mode=default noise-floor-threshold=default nv2-noise-floor-offset=default
periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=static
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled
hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,
ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=full
