MULTICAST ROUTING - PIM SSM
Hi, I’m trying to setup PIM SSM with our wholesale IPTV ISP.
Upstream ISP runs PIM SSM only, I’ve read that Mikrotik supports SSM, but I have a problem that it’s not working.
I have 3.30 version, enabled PIM, added all interfaces to PIM
I see neighbor in PIM, interface from upstream provider shows D and 1 PIM neighbor.
When I connect using VLC to multicast group, I see multicast group in IGMP groups is created, but I don’t see in debug IGMP Join request and nothing is received.
Any IDEA?
Best regards,
Petr
solved?
can you post your cfg?
Not solved. Mikrotik does not support PIM SSM pith static SSM Maps. Use CISCO.
