Hi!
I have multicast trafik iptv and I want forward it to l2tp on my sever.
How can I do this ?
I studied a lot of information and got even more confused, tell me the instructions on how to do this? and in general it is possible?
I working with CCR1036, with 4 sfp. fw: 7.1.1
l2tp nice but maybe this is possible with wireguard ?
If that doesn’t work, then you have to go with the standards-compliant method, PIM-SM. This is considerably more difficult to set up, but it’s the right tool for the job of routing IGMP among 2+ LANs.
igmp proxy can’t help, no packets recieved to upstream interface.
even if I statically write MFC (group 233.1.1.1 source [ip from provider iptv settings] upstream - interface with multicast and downstream l2tp interface)
Is there a Mikrotik on both ends of the L2TP tunnel?
If so, an EoIP tunnel might be easier than L2TP. This point suggests that: https://forum.mikrotik.com/posting.php?mode=quote&p=577031#postingbox
That 2017 post above problem may be that HD was a 30-36Mb/s MPEG-TS “mux”, but his bandwidth was only 27Mb/s – so EoIP seem to work, but yeah you’d need bandwidth.
L2TP is a bit more complex, but multicast PIM should work – if you have multiple L2TP links on the same router to same network get even more tricky. L2TP will compress the MTU, so you’d need to pay attention to how the IPTV stream if framed (e.g. 1427 + 14 RTP + 20+ for IP, get close L2TP default 1450 MTU)
If you want to be a ginny pig, V7 with ZeroTier should able to bridge the multicast, but different/untested approach.
bridge (string; Default: ) Name of the bridge interface to which ppp interface will be added as a slave port. Both tunnel endpoints (server and client) must be in bridge in order to make this work, see more details on the BCP bridging manual.
good news:
l2tp in bridge with multicast interface need to both ends of tunnel be in bridge.
I successfully tested that with 2 mikrotiks l2tp server and client. l2tp connections in bridges transfer multicast to other side)
but I need to connect l2tp from PC under linux.
who know how to make l2tp linux client in BCP bridging mode ?
