Multicast using RB952Ui-5ac2nD-US
Hi all, I would like to send packets via an iPad connected via cable to two receiving computers on my local network. I believe I can use multi-cast for this, and set my endpoint from the iPad to a multicast address I generate on Router OS.
A few questions:
  1. Is this possible on the RB952Ui-5ac2nD-US?
  2. Is the Router OS multicast example in the documentation applicable for this scenario/device?
  3. Do you have any tips/ideas on how best to set this up, or is there some documentation other than the Router OS docs that I should look at?
Thank you!
IGMP snooping ( Layer 2 Multicast Protocol ) is not supported in hardware by this device…
I guess you could use either PIM or IGMP Proxy
See here
https://help.mikrotik.com/docs/display/ROS/IGMP+Proxy
https://help.mikrotik.com/docs/display/ROS/PIM-SM
