Hello
I ant to use pptp server with multicore cpu
this is not supported yet.
Would an option be to install 4 meterouters and have pptp server on that?
Hello
well, not Metarouters, but KVMs. and yes, it should work
With the KVM is there a performance big hit with network traffic?
I only need about 20mbit for each KVM
Thanks Again
20 Mbps?.. how much KVMs? one router should be quite enough ![]()
p.s. as far as I know, nobody have tested such configs in terms of performance…
for me its not how much traffic but how many tunnels.
I Have over 1000 pptp and cpu is maxed on a p4
Sounds like a Xeon is you future.
Tested on ESX4 with i85476 and msi-x and multiqueue per ethernet port, work very good.
3 virtual router (5.0 beta), traffic 200-300 Mb/s
