10G FTTH? It’s coming (my ISP has started a trial), and I could have used something like a beefed-up RB4011 with 2 SFP+ cages. I have a CCR1036 now, but it is both expensive and large (if you don’t have a 19" rack to mount it in).
A. Are you sure that source is able to deliver data with 10Gbs?
B. ISPs always oversell bandwith so I’m not shure if they are able to deliver constant multi 10GB traffic to users. Edge routers will limit their throughput.
C. 5 sec vs 50 sec for 50GB download … OMG … what a difference … 50 min vs 5 min. is a difference but less 1min is not a shame.
Salt offers it in some places in Switzerland too for $50 a month since 2018 so now Swisscom will make a bigger push in FTTH and join the bandwagon. They also have to fight DOCSIS 3.1 .
Many people back up to the cloud.
NVMe is very common now, but not as a data drive. A case for tiering.
I think the new consoles need 10GbE and SATA Express, as well as BDXL.
It would also be better if one could could put a 3.5" SSHD, as the PS4 is now limited to 2TB (15mm does not fit). OK, you can go bigger with an SSD, but it is expensive.
Optional tiered storage using an M.2 2280 NVMe would be highly desirable. Those on a budget would gravitate towards a SATA M.2 and a SATA hard drive or just an SSHD.
The adoption rate of faster than gigabit networking in their major markets is slow, even in 7 years the US, Canada, and Japan are unlikely to have widespread 10 GbE in use. I believe in that time we will see widespread adoption of 5 GbE and 2 Gbps WAN in these locations.
All speculation of course, I have a feeling these consoles will have standard 1 GbE and likely 802.11ax wireless.
This being a networking community people often forget, WAN speeds over 100 Mbps actually aren’t common. Most people are perfectly happy in the 30 - 50 Mbps range.
