I have Internet Bandwidth from two providers ( 10Mbps & 4 Mbps). I have my own IP block of /21 which I want to advertise
using BGP. Also I want to do load balancing between this 2 links (so that I will get total 14 Mbps to use). My RouterOS is
2.9.27. I have implemented BGP peering successfully with both the providers, but couldn’t do load balancing between two links.
When I run traceroute my packets go from one link always.
to help you, we need to know your networks.
however, in a similar scenario, i think to:
announce your /21 on 10 mbps peer
announce your /21 on 4 mbps peer prepending your AS# 1 time
set default local pref on 10 mbps peer
set a low local pref on 4 mbps peer
if supported from 4 mbps peer, set a default local pref on 4 mbps peer for BGP communities that belong to 4 mbps peer.
in this way:
you use 10 mbps for almost download
you use 4 mbps for backup download / as with a short path
you use 10 mbps for upload
you use 4 mbps peer for upload to 4 mbps peer classes and customer classes.
Another way can be to split the /21 into 4 /23 and:
announce on 10 mbps peer the aggregated /21 + the first 3 /23
announce on 4 mbps the aggregated /21 + the last one /23.
In this way backup capability is ok, (aggregated /21), but the first 3 /23 will download from 10 mbps, the last one from the 4 mbps.
Try to change empirically the subnet announced on 4 mbps peer to balance in a good way.
in this scenario the first solution is very simple, but the 4 mbps will be used only a bit.
the second scenario can fullfill the 4 mbps but if a customer or more then one need >4mbps you are fucked
Mikrotik will not support pirated software versions.. eg: 2.9.27
If you can afford a 10mbps link and a 4mbps link you can also afford the incredibly cheap price for a router license.
(offtopic)
I have 2.9.24(l4) licensed version that is still working on a Pentium I 133Mhz beast
(ontopic)
If you can setup OSPF with your providers it will be a lot easier to do load balancing based on bandwidth constants.
