Multilink PPPoE Problems - RB1100AHx2 - is 4.17 Supported?
Hi All,
Others mileage may have varied, but I have had absolutely no luck with Multilink PPPoE on any version of RouterOS other than 4.17. Unless running version 4.17 I have been plagued with weird problems. All of my installations running 4.17 run smoothly, which brings me to my current dilemma.
I need to setup an 8 link Multlink PPPoE connection and have purchased a RB1100AHx2. Does that model support RouterOS version 4.17?
Have any others had success with Multilink PPPoE on any other (newer) version? Here is an example of the problems I run up against, sometimes on a 4 link MLPPP connection the status shows 1 active link when all 4 are actually active (spoke to ISP, ISP sees 4 active PPPoE links in the multilink bundle, or the opposite occurs where the Routerboard shows 8 established links when I only have 4.
Regards,
Bill
