Multiple CPU Support
Does the Router OS support multiple CPU’s?
Nope, not as far as I know -
I’m not using a p4 hyperthreading cpu at the moment, but will eventually. Would it better to turn off hyperthreading so MT will use the full 100% of the CPU instead of half? If thats the way it would work anyhow …
Sam
