Multiple Devices with Same IP Address
I have multiple devices that need to be tested and I would like to connect them to a mikrotik without having to change their default IP addresses to save time and money. I was thinking about creating a vlan for each unit, assign a virtual IP to the vlan, then perform a 1-to-1 nat from the vlan IP to the static IP inside the vlan. Is this possible? (see attached VLAN Plan Diagram) If not, are there any suggestions on how I can perform this task?
Thank you,
James
Gen3_Mikrotik_Plan.pdf (12.9 KB)
