multiple DHCP client
My ISP gives me up to 5 (public) IP’s, but all based upon DHCP. I want to use at least 3 inbound (using DDNS), outbound office and outbound guests. Off course you can have only one dhcp client on an interface. Any other idea’s then using multiple interfaces? (Yes, i tried vlan 1 attached to the wan port, and also a bridge, but neither worked to give me a second IP let alone the third)
Thnx, Tonny
There are different options:
a) multiple routers
b) multiple ports on same router connected to ISP using another switch
c) VRRP hack (now I’d say it’s not as bad as indicated in that post)
Thnx!! I like that trick … it does it nicely and each vrrp instance is in interface so all one can wish for :smiley:
Just mind the gap (the last paragraph here).
