I’m new to MikroTik products and RouterOS, so this might be a very simple fix. I have a CCR-1016-12G running ROS 6.0. I have configured 4 bridges, with a vlan attached to each. The first bridge uses ether 1-4, the second 5-6, the third 7-8, and the fourth 9-11. ether12 serves as my wan interface. The first DHCP server works as expected, however the other 3 are shown as invalid. I have tried attaching the DHCP servers to the vlans, which does not work at all. Am I missing something here?
Edit:
I neglected to assign IP addresses to the vlan interfaces…
indeed, one thing that usually is missing - check if IP address is assigned, check if you have assigned DHCP-server on the master interface, check if IP address is assigned on master interface.
[admin@MikroTik] > ip address print detail
0 address=192.168.0.155/24 network=10.5.8.0 interface=ether1 actual-interface=ether1
1 address=192.168.1.1/24 network=10.5.113.0 interface=ether2 actual-interface=ether2
2 address=10.5.50.1/24 network=10.5.50.0 interface=ether6 actual-interface=ether6
3 address=192.168.88.2/24 network=192.168.88.0 interface=ether2 actual-interface=ether2
so that actual-interface is equal to interface where DHCP-server is assigned.
