Multiple Dude instances running the same IP?
I’m trying to run 2 or more dude server instances over the same pc, it only has one IP. Someone knows how do it?
Thank you for your answer.
maybe explain the objective so we can help you better?
Actually I have one Dude server running in one pc, and we access to it in mode secure with IP and port 2210, now I want on the same PC with the same IP but different port run other Dude server…
Thanks for your answer.
I have successfully setup The Dude on a Windows 7 computer, but I’d also like to run the software on another computer in our network (in case the current computer that’s running the software fails).
Question 1: Can I run the software on Windows Server 2008? Reason I ask is because I tried to do a fresh install on a freshly built Server 2008 box, but I could never get The Dude server to connect (kept getting a “connection failed 10061” error message).
Question 2: Is is possible to run two different instances of the software on two different computers on our domain network? Since I haven’t been successful at attempting it, I just wanted to make sure it’s possible.
