Hi all, i trying to establish several EoIP tunnels. Searching the forum i found this topic http://forum.mikrotik.com/t/how-to-create-multiple-eoip-tunnels/26954/1 but is not clear to me,
i established 2 tunnels with bridged interfaces ( @wiki) and working well, but what about if i want to add more sites on the main router to share the bridged interfaces? Is it enough to add more EoIP interfaces with the same tunnel id on main router in order to share the bridged interface with the other sites?
each tunnel should have it’s own id, then add them as a port on your single big bridge.
Jorge
Tnx for reply,
the problem is that in bridge under ports i have bridge ethe1 and Eoip interfaces and i can’t add second bridge withe new EoIP and the common bridge port
solved!!
meth: How did you solve? Interested in sharing?
