Multiple gateway
Hello from Bosnia.
How to configure multiple Gateways in RouterOS. First Gateway must be main, but second have to work in case of first GW overload
Thnx
IMO there are no way to tell that you have loaded your first link full, just if it is up or down.
i would suggest to you that you use load balancing.
some examples here:
http://wiki.mikrotik.com/wiki/Bandwidth_Managment_and_Queues
OK, But how to choose prefered GW. I don’t want to route equally trafic to both GWs, or to route same subnet trough same GW. Second GW act as a Backup connection.
