Hello Everyone.
I am wandering if its possible to setup Multiple Hotspot Servers Profiles with Different IP pools on just one Router OS installation?
Will appreciate any help towards achieving this Pls.
Hello Everyone.
Yes. You can set up multiple hotspots on router. Attach each one to specific vlan, virtual WLAN or Ethernet port.
Can U give an example? Ming U I already have an existing Hotspot Profile attached to an Ethernet Interface.
Create a virtual Ap interface
Add a unique ip and network to it, say 10.1.50.1/24
Got to hotspot and, using the wizard, add a hotspot to that interface.
If you require unique HTML pages create a new folder, say hotspot2, and specify that directory in the server profile for the 2 nd hotspot.
That should do it ok.
Note there are RouterOS limits on numbers of connected users so you may need a RoS level 5 or 6 capable routerboard if large numbers (over 200) are required or CPU is too busy.
If the post was helpful please give Karma ![]()
