Multiple If Statements
Hello!
I’m having an issue when using multiple IF statements. The code doesn’t seem to run :
:log info "Hi"
:local a 1
:local b 2
:local c 3
:if ($a=1) do={
:log info "A is definitely 1"} else={
:if ($a=2) do={
:log info "A is definitely 2"} else={
:log info "A is not 1 or 2"}
BUT if we remove the second if statement, the code runs perfectly fine:
:log info "Hi"
:local a 1
:local b 2
:local c 3
:if ($a=1) do={
What am i doing wrong?
If you fix your formatting, the problem becomes obvious: You’re missing a closing brace for the first else.
:if ($a=1) do={
} else={
    :if ($a=2) do={
    } else={
Wow. I feel stupid. Thank You!
