multiple interface on one hotspot server, is it possable i tried many many times but it didnt works?
i cannot find any decumntation that could help me?
try to help me gys waiting for your answers
What exactly is your goal? What have you tried? Have you tried putting a Hotspot on a bridge that contains your 2 interfaces? More info will get you a lot more help…
yeah the same problem (dunno if its a real problem)…
I can’t configure more than 2 NIC’s on the same mikrotik, but you mentioned about bridging… what do u mean exactly?
Regards
No dont try that. Create a new hotspot server and profile for the second interface with separate dhcp server pools. We have some in hotels where
we have the radio card providing the main AP through an aerial on the roof with one hotspot, then a low cost wireless bridge such as a Belkin 7230 connected through ethernet to the mT, configured as the second hotspot interface providing bar access. You can use the same hotspot html directory in the second profile. It works fine provided you keep the addresses in the two hotspots separate..
I try to put a wireless interface and an ethernet interface in an only bridge interface, the IP address only in the bridge interface and hotspot server setted to the bridge interface but have problems… bad experience.
I recommend to do 2 hotspots servers with differents interfaces, ip addresses, IPs ranges, dhcp-servers, pools… but with the same profiles and html directories. This work very fine!
Regards!
so all of has having the same problem
but for me i want it to be like this so i can access all my MT access point throw winbox
taloot,
have you tried to recommended perform HotSpot setup ?
(for interface=bridge)
Give more detailed desription about ‘access all MT AP trough Winbox’,
(are there any MikroTik routers connected to another/main MikroTik router performing NAT ?)
yes sergejs,
1st question yes i did and i sent for you the supout
2nd question
i have only one router + AP on it and wds station on the another side but i cant access the remote AP"which is wds staion"
only when using mac telnet ip neighbor <— in this one only i can ping MAC and telnet MAC,
btw the wds interface is hotspot enabled <—which on the main router+AP
