Multiple IP Pools on different LAN ports
Hello guys,
I’m kinda’ of n00b in Mikrotik and Router OS, I succeded connecting a PPPoE client on the router and a PPTP server to acces remotely via VPN the router, but now I’m in a really big concern. Is there anyway, for example, for LAN port 1-3 to have a DHCP server that will lease IP addresses from the pool 192.168.1.1-192.168.1.100 for example, and for the LAN 4, to release IP addresses from the pool 10.11.12.1-10.11.12.100?
I’m asking because I tried to add a seconday DHCP Server and I got the error "Couldn’t add New DHCP Server - can not run on slave interface (6).
Any help is appreciated.
The correct way will be to configure VLAN’s for each subnet in a single bridge, alternative, you can remove ether4 from the current bridge and create the 2nd DHCP on ether4
