i try to create multiple IPSec over L2TP VPN’s for different groups of “road warriors”.
At the moment i have one working VPN.
0.0.0.0/0 peer, group for vpn, a default template in policies and some credentials in PPP
Because i don’t want to share the same IPSec secret between every road warrior group, i decidet to make a 2nd vpn.
I duplicated everything i use for the first VPN and make some customisations (define local IP, shared secret, ipsec group, default policy template…)
But if i want to connect to the 1st vpn, it did’nt work until i disable the 2nd default peer. Ther is also nothing going to the ipsec logs when the 2nd peer is enabled. If its disabled, i see the connection in the log.
