I have srcNAT connection problems with wifi clients. The connection below is being used on a CCR router with CAPSMAN enabled. wifi clients connect, get an IP address from one single /16 subnet which ist srcNATed to 4 public ip addresses. For the public ip addresses OSPF is enabled, so ECMP should be used. Unfortunately, the public IP which is used for srcNAT is not respected. It seems OSPF ECMP changes this one randomely which breaks TCP connection at all. Hopefully it is clear what I say?
Let´s look at the configuration on the CCR
- DHCP server
add address=10.40.0.0/16 dns-server=10.40.0.241 domain=hob.com
gateway=10.40.0.240 netmask=16
- OSPF interfaces + network
/routing ospf interface
add interface=vlan2081 network-type=broadcast
add interface=vlan1000 network-type=broadcast passive=yes
add interface=vlan2082 network-type=broadcast
add interface=vlan2083 network-type=broadcast
add interface=vlan2084 network-type=broadcast
/routing ospf network
add area=backbone network=195.0.1.5.20/32
add area=backbone network=195.12.108.0/30
add area=backbone network=195.12.108.4/30
add area=backbone network=195.12.108.8/30
add area=backbone network=195.12.108.12/30
- OSPF routes, i.e. /routing ospf route> print
0.0.0.0/0 ext-2 1
195.12.108.1 vlan2081
195.12.108.5 vlan2082
195.12.108.9 vlan2083
195.12.108.13 vlan2084
- srcnat:
add action=src-nat chain=srcnat connection-limit=!100,32 log=yes log-prefix=
src0 src-address=10.40.0.0/19 to-addresses=195.12.108.2
src64 src-address=10.40.32.0/19 to-addresses=195.12.108.6
src128 src-address=10.40.64.0/19 to-addresses=195.12.108.10
src192 src-address=10.40.96.0/19 to-addresses=195.12.108.14
src0 src-address=10.40.128.0/19 to-addresses=195.12.108.2
src64 src-address=10.40.160.0/19 to-addresses=195.12.108.6
src128 src-address=10.40.192.0/19 to-addresses=195.12.108.10
src192 src-address=10.40.224.0/19 to-addresses=195.12.108.14
src16 src-address=10.40.0.0/16 to-addresses=195.12.108.2
e.g.
- my client has 10.40.72.111
- So public NAT IP 195.12.108.10 should be used
- Browsing to showip.net it shows 195.12.108.2
So OSPF ECMP mixes with srcNAT. So it seems I have to get OSPF up and running with some kind of “routing-mark” policies. Those below don´t work:
/ip firewall mangle add chain=prerouting src-address=10.40.0.0/19 action=mark-routing new-routing-mark=r_src0
/ip firewall mangle add chain=prerouting src-address=10.40.32.0/19 action=mark-routing new-routing-mark=r_src32
/ip firewall mangle add chain=prerouting src-address=10.40.64.0/19 action=mark-routing new-routing-mark=r_src64
/ip firewall mangle add chain=prerouting src-address=10.40.96.0/19 action=mark-routing new-routing-mark=r_src96
/ip firewall mangle add chain=prerouting src-address=10.40.128.0/19 action=mark-routing new-routing-mark=r_src128
/ip firewall mangle add chain=prerouting src-address=10.40.160.0/19 action=mark-routing new-routing-mark=r_src160
/ip firewall mangle add chain=prerouting src-address=10.40.192.0/19 action=mark-routing new-routing-mark=r_src192
src0 routing-mark=r_src0 src-address=10.40.0.0/19 to-addresses=
195.12.108.2
src64 routing-mark=r_src32 src-address=10.40.32.0/19 to-addresses=
195.12.108.6
src128 routing-mark=r_src64 src-address=10.40.64.0/19 to-addresses=
195.12.108.10
src192 routing-mark=r_src96 src-address=10.40.96.0/19 to-addresses=
195.12.108.14
src0 routing-mark=r_src128 src-address=10.40.128.0/19 to-addresses=
195.12.108.2
src64 routing-mark=r_src160 src-address=10.40.160.0/19 to-addresses=
195.12.108.6
src128 routing-mark=r_src192 src-address=10.40.192.0/19 to-addresses=
195.12.108.10
src192 routing-mark=r_src224 src-address=10.40.224.0/19 to-addresses=
195.12.108.14
add distance=1 gateway=195.12.108.9 pref-src=195.12.108.10 routing-mark=
r_src192
add distance=1 gateway=195.12.108.13 pref-src=195.12.108.14 routing-mark=
r_src224
add distance=1 gateway=195.12.108.1 pref-src=195.12.108.2 routing-mark=r_src0
add distance=1 gateway=195.12.108.5 pref-src=195.12.108.6 routing-mark=
r_src32
r_src64
r_src96
r_src128
r_src160
e.g.
- Browsing to showip.net it shows 195.12.108.2 sometimes
I forget to mention that I added a “catch it all” rule in “ip firewall nat” at the end, which is being used, when that “error” occurs:
add action=src-nat chain=srcnat connection-limit=!100,32 log=yes log-prefix=\
Why is it being used at all? There shouldn´t be any match as I catch everything with the rules above…
So I added logging to this rule with “src-catch-all” and hit “F5” for reloading the homepage:
2019-03-15 11:59:06 Local7.Debug firewall,info src-catch-all: src192 srcnat: in:(unknown 0) out:vlan2084, src-mac 20:16:b9:10:a2:0a, proto TCP (SYN), 10.40.72.111:58906->13.23.19.91:443, len 52
2019-03-15 12:01:14 Local7.Debug firewall,info src192 srcnat: in:(unknown 0) out:vlan2084, src-mac 20:16:b9:10:a2:0a, proto TCP (SYN), 10.40.72.111:50906->13.23.19.91:443, len 52
=> different public IPs are being used
