Multiple network segments of same class c network
I am using version 3.0beta 7 of The Dude and so far, I absolutely love it! I do have one question / concern:
Both under Netowrks and on the Network Map it adds multiple instances of the same Class C network (which is my LAN). I can remove all but one copy under Networks and it will repopulate with more of the same.
For example:
Under Networks, The Dude is showing Netowrk #1 - Network #12 all using Subnet 10.20.10.0/24 and all on the same network map.
Why is this? Can I prevent this and config The Dude to only show a single instance of my network?
Thanks so very much.
Delmar
yes…just discover or edit the network and make sure your subnet mask is right… i have /29 /24 /26 networks plotted fine…
I double checked network settings and it is correct: 10.20.10.0/24
Also, if I remove all but on instance of the network segment, within an hour or so The Dude will start showing multiple segments for 10.20.10.0/24 again - on both the Map and under Network…
Thanks,
Delmar
