I have a problem routing between two networks on my RB1100 that I can’t figure out.
On my RB1100 I have a 192.168.1.0/24 network and hosts.
I also have, separately, a device (an IP phone controller) which runs a DHCP server for the IP phones on the 192.168.42.0/24 network. Its web management is accessible from this network at http://192.168.42.1.
I would like to connect the IP phone controller to a port on the RB1100 such that I can access its UI at http://192.168.42.1 from any host on the 192.168.1.0/24 network.
To do this, I freed up a port from the RB1100’s bridged port, and added a dhcp-client to it. It gets an address:
9 D 192.168.42.86/24 192.168.42.0 ether1-phone-controller
And a route is dynamically added:
29 ADC 192.168.42.0/24 192.168.42.86 ether1-phone-controller 0
And I can ping it from the RB1100:
[admin@RB1100] > ping 192.168.42.1
HOST SIZE TTL TIME STATUS
192.168.42.1 56 99 0ms
..But, I cannot reach 192.168.42.1 from any 192.168.1.0/24 host.
Any idea what I am doing wrong here?
Many thanks!
you need to add an additional route from the 192.168.1.0/24 network to be able to access the 192.168.42.0/24 network
Hey fallenwrx,
Would you mind explaining what route I need to add?
Adding:
/ip route add dst-address=192.168.42.0/24 gateway=ether1-phone-controller
doesn’t work.
Thanks!
add
/ip route add dst-address=192.168.42.0/24 gateway=192.168.1.1
if that doesnt work please post entire configuration for clarity.
The devices on your 192.168.1.0 network, are they using the 1100 as their default GW (192.168.1.1)?
If so, then you’re not going to need to add any static routes.
It sounds like it’s the voip server which needs a static route added - if it’s a DHCP server, and it is 192.168.42.1 - it sounds like this device wants to be a default GW for devices attached to it…
You need to make the Mikrotik have a static IP address on the 42 network (e.g. 192.168.42.254)
You need to configure the voice gateway to use the Mikrotik as either a default GW, or else a specific gateway to reach 192.168.1.0/24
If there are no other networks attached to the voice server, then simply set its default GW to be 192.168.42.254
If it has its own inernet connection, then you need to add a static route with destination 192.168.1.0/24 (mask = 255.255.255.0 if it uses that notation) and gateway (next hop) = 192.168.42.254
Finally, make sure the Mikrotik has no rules that would block traffic between these networks, and also make sure that none of your NAT rules will match this traffic either.
That should be everything. (assuming I’m right about the voice gw wanting to be a router)
