My ISP offer multiple IPs just with multiple PPPoE user.
So…I have 3 PPPoE users from ISP with on IP on each user.
My problem is when I try to ping to all IPs I have response just from one. I try with change distance default route but not working.
Can anybody help with that ?
Best Regards,
Sob
June 26, 2018, 12:49pm
2
You can find some inspiration here:
https://wiki.mikrotik.com/wiki/Manual:PCC
Ignore the main topic of the article, and just focus on how incoming traffic from each WAN gets own connection mark and how returning traffic gets the right routing mark, based on previously set connection mark.
Hi try that.
My problem is PPPoE because I don’t hav IP for default gateway
Sob
June 26, 2018, 9:22pm
4
It’s actually even easier with PPPoE, because it supports gateway=.
Now problem is router. Unable to work with DNS. When I ping at google.com host not found but when I ping at 8.8.8.8 work.
This is my configuration.
Please can anybody help me ?
add fast-forward=no name=bridge1-LAN
/interface pppoe-client
add disabled=no interface=ether1 name=PPPoE-1 password=XXX user=User1
add disabled=no interface=ether1 name=PPPoE-2 password=XXX user=User2
add bridge=bridge1-LAN interface=ether3
add bridge=bridge1-LAN interface=ether4
add bridge=bridge1-LAN interface=ether5
add address=192.168.16.1/22 interface=bridge1-LAN network=192.168.16.0
add address=192.168.16.0/22 dns-server=192.168.16.1 gateway=192.168.16.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=fasttrack-connection chain=forward
/ip firewall mangle
add chain=prerouting in-interface=PPPoE-1
add chain=prerouting in-interface=PPPoE-2
add action=mark-routing chain=prerouting connection-mark=PPPoE-1_conn new-routing-mark=PPPoE-1-wan1 src-address=192.168.16.0/22
add action=mark-routing chain=prerouting connection-mark=PPPoE-2_conn new-routing-mark=PPPoE-2-wan2 src-address=192.168.16.0/22
add action=masquerade chain=srcnat out-interface=PPPoE-1 src-address=192.168.16.0/22
add action=masquerade chain=srcnat out-interface=PPPoE-2 src-address=192.168.16.0/22
add check-gateway=ping distance=1 gateway=PPPoE-1 routing-mark=PPPoE-1-wan1
add check-gateway=ping distance=1 gateway=PPPoE-2 routing-mark=PPPoE-2-wan2
add check-gateway=ping distance=1 gateway=PPPoE-1,PPPoE-2
Best Regards,
Thank You for your answer but it is not for PPPoE.
I read on wiki and I found that:
add distance=1 gateway=10.0.0.1%PPPoE-1 routing-mark=WAN1
add distance=1 gateway=10.0.0.1%PPPoE-2 routing-mark=WAN2
Now problem just 1 IP respond at ping from outside.
In log I see:
prerouting: PPPoE-1 out:(unknow 0), src-mac 4c:f9:55:44:55 TCP (ACK,PSH),…
Regards,
