Multiple pppoe connections with subnet?
is the following situation possible with RouterOS?
I have two pppoe connections: pppoe-out1 and pppoe-out2
They have the public IPs 80.1.1.1 and 80.1.1.2
Also the ISP routes two subnets to those IPs: 1.1.1.0/24 and 2.2.2.0/24
Now given that the ISP will also prevent IP spoofing so that traffic from and to 1.1.1.0/24 can only pass through pppoe-out1…
Will this still work?
I’m not too experienced with IP routing but I suspect as both pppoe-interfaces will add a default gateway rule the traffic might take the wrong interface on it’s way back.
Best regards
Max
you may use routing rules. or just routing mark from mangle
Thanks,
I found some examples at the end of this pages which match my situation:
http://www.mikrotik.com/documentation/manual_2.7/IP/Route.html#ht382128020 (won’t work anymore)
http://www.mikrotik.com/testdocs/ros/2.9/ip/route_content.php#.4.2
