Multiple PPPOE servers failover
In our network we have multiple PPPoE servers, which have fiber link into a central router. Now we have the ability to have a network with PPPoE server at each end, allowing customers to connect to the router that responds fastest. But then comes the challenge of routing. I have tested putting two gateways in the main router, (ex aaa.aaa.aaa.aaa / aa gateway = bbb.bbb.bbb.bbb, ccc.ccc.ccc.ccc) it works, but does not completely stable. How can I set up the main router so it forwards the packet correctly regardless of the PPPoE client router is connected. The challenge is that some of the customers have a fixed IP. Had all been dynamic, there had not been a problem … Any advice?
I have used Google to translate, so it’s probably a little bad English.
