Multiple Public IPs
I have a MikroTik 4.2 working as PPPoE.
I’m forwarding port 80 from the public IP that gets assigned to the PPPoE port to a web server
inside. Everything works great.
Now I need to install another web server “inside” with another public ip which is already been routed
to the same PPPoE connection. How do I configure the MikroTik?
Thanks!
Assuming a very simple network;
Internet===<PPPoE>===[MikroTik]===LAN (including host you want 2nd public IP routed to)
assuming that you will NOT be doing filtering or NAT/Masquerading on any packets with the 2nd public IP as either SOURCE or DESTINATION address;
assuming your ISP has correctly routed the 2nd public IP to your 1st public PPPoE IP;
AND assuming the internal (LAN) host to which you want the 2nd IP routed has BOTH a local LAN IP address that won’t change AND also is configured with the 2nd public IP;
THEN the solution is as simple as adding a single static route:
/ip route add dst-address=2ND.PUB.LIC.IP/32 gateway=LAN.IP.OF.HOST
If on the other hand, the internal LAN host ONLY has a private LAN IP, then you will need to set up NAT rules.
Aaron out.
I’m guessing your situation would look like:
Internet===<PPPoE 1>===[MikroTik]===LAN: Server 1 & Server 2
        ===<PPPoE 2>===
And you want it in such a way that if someone access PPPoE 1’s IP:80, it should forward to Server 1, and PPPoE 2:80 should forward to Server 2?
For this setup, you would simply need 2 separate dstnat NAT entries:
  • One with the the In Interface=PPPoE1 and the To Address & Port pointing to Server 1,
  • and one with the In Interface=PPPoE2 and the To Address & Port pointing to Server 2
The code would look something like:
 add chain=dstnat action=dst-nat to-addresses=10.0.0.100 to-ports=80 protocol=tcp in-interface=pppoe1 dst-port=80
 add chain=dstnat action=dst-nat to-addresses=10.0.0.101 to-ports=80 protocol=tcp in-interface=pppoe2 dst-port=80
Thanks astounding. It worked!
I just added NAT so I didn’t need to change the server settings.
GREAT HELP! thanks again.
