Multiple Public Networks - One dude to reade multiple other
I hope someone can answer this for me.
I have 5 Mikrotik Networks which I monitor aorund the country and I havr to remote into the machine on each network that has the dude server on for that network.
Is it possible for those networks to upload the data to one central dude server? so I can view multiple networks.
The config I have is multiple networks, with one public IP at each that I can reach and another central Public IP that has my main Network Operations Centre. Is this possible, or does anyone have any other suggestions to solve this?
Freefall :slight_smile:
How about setting up the dude server at your NOC and then setting up VPNs to your networks to get the data from them?
I have thought of that, Each network has the same IP Ranges so I will run into problems no?
Freefall
Hmm…I’m not sure. The VPN interface at each end of the link has it’s own IP address so maybe you could NAT from the LAN IP address to the VPN interface address?
I did specifically set up each of my remote networks with a different private IP range for this reason. Would it be a big deal to renumber them?
I will definitly run into problems.
The equipment has to stay on the IP addresses they are on.
Any ideas from the admins on this??
