Multiple radius clients
Hi
Has anyone configured more than one radius server per hotspot configuration? I have a situation where a radius server has some accounts that need to run until a certain date but other active accounts are found on another radius box. I need to run these side-by-side until D-day.
I added both radius servers and enabled it for hotspot hoping that if the first failed it would try the second, but it seem not work that way.
Any advice?
I think that second is used only when first one doesn’t return response… You can’t check second if first doesn’t have user because first generates valid response
