hi all
please i need your help
i have MIKROTIK and i need to active two RADIUS at the same time and each RADIUS has its clients, how can i do that ?
hi all
If you can use different SSID’s for those 2 groups of clients: It’s simple then: one RADIUS per SSID
I removed the MAC from the “Called ID format”.
thank you for your replay
i am connecting the mikrotik with 2 outside RADIUSs in a server
the upper RADIUS is the one that works and the lower does not work until i place it up
The selection of the RADIUS server in my case is based on the “called id”. Is there a way to specify this “called id” with your ppp/hotspot services?
But maybe “Domain” could also be used as differentiator between the 2 radius servers. I have no experience with this.
also works in v7
https://help.mikrotik.com/docs/display/ROS/WifiWave2#WifiWave2-AAAproperties
called-format (format-string)
Format for the value of the Called-Station-Id RADIUS attribute, in AP’s messages to RADIUS servers. Default: II-II-II-II-II-II:S
… and if you don’t use the exact syntax … you may end up here:
( unnecessarily : | )
#### Filter Called-Station-ID
filter_calledstationid {
if (&Called-Station-Id) {
if (&Called-Station-Id =~ /(.+)\:ssid-name-a$/) {
update control {
Proxy-To-Realm := 'fac.net'
if (&Called-Station-Id =~ /(.+)\:ssid-name-b$/) {
update control {
Proxy-To-Realm := 'ubi.net'
else {
noop
AAA properties
Properties in this category configure an access point’s interaction with AAA (RADIUS) servers.Certain parameters in the table below take format-string as their value. In a format-string, certain characters are interpreted in the following way:
a Hexadecimal character making up the MAC address of the client device in lower case
A Hexadecimal character making up the MAC address of the client device in upper case
i Hexadecimal character making up the MAC address of the AP’s interface in lower case
I (capital ‘i’) Hexadecimal character making up the MAC address of the AP’s interface in upper case
N The entire name of the AP’s interface (e.g. ‘wifi1’)
S The entire SSID
All other characters are used without interpreting them in any way. For examples, see default values.
still struggeling
what does it mean ??
For examples, see default values. ??
can I use: “08-A9-8A-II-II-II:myrealssid” ?
All other characters are used without interpreting them in any way. … used without interpreting … is this a wildcard … or bananas ?
