Multiple remote hotspot from a single userman
Hello friends. I have remote routers configured correctly and properly authenticated clients from each location. The problem I have when a user expires or when I try to close sessions dont disconnect from remote routers. Any ideas? Thanks
Please clarify in more details, how user is expired.
Does it have session-timeout limit configured to the user?
Thanks for answering. Only I try to close active session by selecting the user and clicking edit / logout in active sessions with local users no problem but with the remote routers me indicates failure in the operation
What error do you get? Could you post screenshot here?
“operation failed” and no disconnects me users on the remote server. If you try the two servers in lan doing well but passing through an area not wan’s me off. Open ports and remove all filters but something escapes me to work correctly COA ports or something. Thank You
As I see, the best way to Kick the Users out is to use GUI of mikrotik. I mean Webfig. so i made low access user for my employers so that they can kick the user without problem.
And yes, I know you have problem with UM. just consider this post as suggestion :smiley:
