Is it possible to plug in a single power adapter in a wall socket, then run poe and split the poe’s power between 2 routerboards?
If not, is it possible to run normal 230V power through an ethernet cable without the plastic melting?
I basically have one ethernet cable to use to get power. Its the only cable running between power source and routerboards. I cant get more cables in the hole.
