Multiple routers same certificate
Hello evryone i would need some help please!
Scenario:
I have 5 MikroTik routers with 5 diffrent WAN IPs, for Windows clients i would like to create one CA that i would export from one of the mikrotiks and import to client, and with this cert they could connect to evry SSTP MikroTik routers.
So my idea is:
Router 1:
Create CA,
create Router1Cert => Sign with CA
create Router2Cert => Sign with CA
Export CA and Router1Cert
Router 2:
import Router1Cert
setup for use with sstp
the same with router 3, 4, 5.
Client:
Import CA cert
add vpn SSTP for router1,2,3,4,5 so they could connect with the same cert to all routers.
Can someone please give me some practical example how i would achive these.
Thank you for any advice in advance.
I hope i wrote clear enough
