Multiple routers to with same pppoe accounts question
We have two routers and for the meantime, need to have the same PPPOE accounts on both. Other than exporting, is there a way that if I create an account on one router that the same account will be created on the other one as well without manually creating them on each router?
Like is it possible for one of our routers to act like a reference for the other?
Thanks.
  1. On the first router open terminal and type:
 /interface pppoe-client export
  1. On 2nd router paste the exported line.
But some ISPs don’t allow multiple pppoe connections on the same line.
