Multiple subnets/wans routing
Hi, I need help with Multiple subnets/wans routing network topology .
Issue is that I can not ping gateway of Zyxel network (172.16.10.1) from bridge1 on Mikrotik (192.168.10.0/24) although I can ping all other Zyxel network members (172.16.0.0/16). What is wrong (wireless station mode of wlan, arp mode or source nat?
[hineni@kavka] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   10.7.125.134/30    10.7.125.132    ether1
 1   192.168.10.1/24    192.168.10.0    bridge1
 2   172.16.10.200/16   172.16.0.0      wlan3
[hineni@kavka] > interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1526            00:0C:42:77:71:F7
 1  RS ether2                              ether            1500  1522       1522 00:0C:42:77:71:F8
 2  RS ether3                              ether            1500  1522       1522 00:0C:42:77:71:F9
 3  RS ;;; FAZIN
       wlan1                               wlan             1500  1600       2290 00:0C:42:6D:53:C2
 4  R  ;;; ZYXEL
       wlan3                               wlan             1500  1600       2290 00:0B:6B:84:95:12
 5  R  bridge1                             bridge           1500  1522            00:0C:42:6D:53:C2
[hineni@kavka] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE                                               BRIDGE                                              PRIORITY  PATH-COST    HORIZON
 0    ether2                                                  bridge1                                                 0x80         10       none
 1    ether3                                                  bridge1                                                 0x80         10       none
 2    wlan1                                                   bridge1                                                 0x80         10       none
[hineni@kavka] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 A S  0.0.0.0/0                          10.7.125.133              1
 1 ADC  10.7.125.132/30    10.7.125.134    ether1                    0
 2 ADC  172.16.0.0/16      172.16.10.200   wlan3                     0
 3 ADC  192.168.10.0/24    192.168.10.1    bridge1                   0
Please explain better what you want to achieve.
Load balancing?
I dont want load balancing mikrotik have default route only on wan1, Zyxel LAN network should be only accesible from mikrotik.
I would connect to Zyxel router itself for management (172.16.10.1) from computers on bridge1 (192.168.10./24).
Now I can connect only all other computers on (172.16.0.0/16) but not Zyxel itself (172.16.10.1).
You should add static route on Zyxel Router to access other routes.
If Zyxel have default route pointing internet, it couldn’t access inside networks.
Regards.
You are right about static route on Zyxel if I want connect Mikrotik lan network from Zyxel network, but I do not want.
I want connect only from Mikrotik network to Zyxel network and I already have static route on Mikrotik for this (ADC 172.16.0.0/16 172.16.10.200 wlan3).
I can connect now from Mikrotik all Zyxel network (172.16.0.0./16) except Zyxel itself 172.16.10.1 how can I fix it?
Did you check if you have some firewall in Zyxel router?
Thats not a problem, I can connect to Zyxel from its local LAN without problem. Zyxel is dumb device, anyway firewall is off.
From witch IP Adress are you trying to connect?
As I wrote before I try to connect from any of this IP range (192.168.10.0/24 - mikrotik LAN bridge1) to 172.16.10.1 ( I can connect all subnet 172.16.0.0/16 except 172.16.10.1).
Try to add this firewal nat rules to your MikroTik Router
add action=masquerade chain=srcnat src-address=192.168.10.0/24
add action=masquerade chain=srcnat dst-address=192.168.10.0/24
If the ping works it confirms the problem is in Zyxel routing table.
