On our network we have multiple tagged VLAN’s ( 90+ ) from CCR2116 to D-Link 24 port switch > PTP > D-Link 24 port switch and this switch it has some PTP’s + AP’s connected to most ports!
Now this my question - as each connected has multiple Tagged VLANs -
(1) Should each port be set as “Trunk” and add “Allowed VLAN Range” tagged with “Ingress Checking” enabled ?
(2) Or should I set the port as “Hybrid” and create a PVID for each port and add the tagged VLANS as a member of that port?
Many thanks for your reply and I also had a preference for trunk mode but not sure how it would work with mikrotik ?
Before I post on D-link forum can i ask do you use “Allowed VLAN Range” tagged with “Ingress Checking” enabled or just allow all Vlans’s on the trunk ports?
On my trunk ports I have ingress checking enabled and admit all for frame types. I suppose I could change that to tagged only as that is what is proper.
