Hi
I wanna to simulate multiple connected wireless clients using 1 physical wlan interface, all clients connected to 1 AP (non mikrotik device).
Configuration on AP:
bridge with wl0, essid: test, bridge ip 192.168.1.1/24.
conf on Mikrotik side:
adding 2 wireless clients:
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge
add disabled=no keepalive-frames=disabled mac-address=6E:3B:6B:07:85:5B \
master-interface=wlan1 multicast-buffering=disabled name=client1 ssid=test \
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=6E:3B:6B:07:85:5C \
master-interface=wlan1 multicast-buffering=disabled name=client2 ssid=test \
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys wpa2-pre-shared-key=test_pass
/interface wireless> print
0 name="client1" mtu=1500 l2mtu=1600 mac-address=6E:3B:6B:07:85:5B
arp=enabled interface-type=virtual master-interface=wlan1 mode=station
ssid="test" vlan-mode=no-tag vlan-id=1 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
1 name="client2" mtu=1500 l2mtu=1600 mac-address=6E:3B:6B:07:85:5C
2 name="wlan1" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:07:85:5B arp=enabled
interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroTik"
frequency=2412 band=2ghz-b/g channel-width=20mhz scan-list=default
wireless-protocol=any vlan-mode=no-tag vlan-id=1 wds-mode=disabled
compression=no
IP addresses, arp entry:
add address=192.168.1.11/24 interface=client1 network=192.168.1.0
add address=192.168.1.12/24 interface=client2 network=192.168.1.0
/ip arp
add address=192.168.1.1 interface=client1 mac-address=A4:5D:A1:76:E8:6D
add address=192.168.1.1 interface=client2 mac-address=A4:5D:A1:76:E8:6D
VRF
/ip route vrf
add interfaces=client1 routing-mark=vrf_cl1
add interfaces=client2 routing-mark=vrf_cl2
ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 192.168.1.0/24 192.168.1.11 client1 0
1 ADC 192.168.1.0/24 192.168.1.12 client2 0
trying to run ping command simultaneously from 2 clients:
ping 192.168.1.1 routing-table=vrf_cl1
ping 192.168.1.1 routing-table=vrf_cl2
I can see all packets on my AP (non mikrotik device):
11:32:31.037888 6e:3b:6b:07:85:5b (oui Unknown) > a4:5d:a1:76:e8:6d (oui Unknown), ethertype IPv4 (0x0800), length 70: 192.168.1.11 > 192.168.1.1: ICMP echo request, id 278, seq 935, length 36
11:32:31.038261 a4:5d:a1:76:e8:6d (oui Unknown) > 6e:3b:6b:07:85:5b (oui Unknown), ethertype IPv4 (0x0800), length 70: 192.168.1.1 > 192.168.1.11: ICMP echo reply, id 278, seq 935, length 36
11:32:31.326986 6e:3b:6b:07:85:5c (oui Unknown) > a4:5d:a1:76:e8:6d (oui Unknown), ethertype IPv4 (0x0800), length 70: 192.168.1.12 > 192.168.1.1: ICMP echo request, id 278, seq 936, length 36
11:32:31.327454 a4:5d:a1:76:e8:6d (oui Unknown) > 6e:3b:6b:07:85:5c (oui Unknown), ethertype IPv4 (0x0800), length 70: 192.168.1.1 > 192.168.1.12: ICMP echo reply, id 278, seq 936, length 36
but on Mikrotik I see only icmp packets on one interface, when I disable that interface I can see packet on the second one:
00:30:31 firewall,info input: in:client1 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.11, NAT 192.168.1.1->192.168.1.11, len 56
00:30:32 firewall,info input: in:client1 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.11, NAT 192.168.1.1->192.168.1.11, len 56
00:30:33 firewall,info input: in:client1 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.11, NAT 192.168.1.1->192.168.1.11, len 56
00:30:33 wireless,info A4:5D:A1:76:E8:72@client1: lost connection, disabling
00:30:33 wireless,info A4:5D:A1:76:E8:72@client2: lost connection, disabling
00:30:33 system,info device changed by admin
00:30:34 wireless,info A4:5D:A1:76:E8:72@client2 established connection on 2412000, SSID test
00:30:34 firewall,info input: in:client2 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.12, NAT 192.168.1.1->192.168.1.12, len 56
00:30:35 firewall,info input: in:client2 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.12, NAT 192.168.1.1->192.168.1.12, len 56
00:30:36 firewall,info input: in:client2 out:(none), src-mac a4:5d:a1:76:e8:6d, proto ICMP (type 0, code 0), 192.168.1.1->192.168.1.12, NAT 192.168.1.1->192.168.1.12, len 56
What I missed in that configuration to be able to ping from two interfaces at once ?
