Multiple VLAN ID over wireless link, possible?
a lot of unmanaged switches do not support 802.1q tags, so you’ll have to treat it like an access port.
cybernet,
Thank you for your post, yes i am using unmanageable switch, so i want to overcome this situation.
I do not understand about your post,
If you have same situation, maybe you can post what you have accomplish.
For now, we are using EOIP.
Do you have other solution?
Thank you
http://wiki.mikrotik.com/wiki/802.1q_Trunk_extension_over_Wireless_P2P_Link
This is all you require.
Thanks,
Sudipta
mr. sudiptakp
i’ve used that link b4, and i still couldn’t get it to work…i know this is a old post reply…but what else is needed to make it work…im using rb433uah i believe it is
