all,
l want to pass multiple vlans on wlan interface without adding bridge in Client RB411
if i add one vlan in same case it will work perfectly,
the case is adding second or more vlan in client modem ( RB411)
thanks in advance
all,
thanks in advance
Can you please explain what you’d like to do.
You can add multiple vlans on whatever interface youd like. but the way you are trying to do it doesn’t make sense (to me).
hi,
i wnat to allow mutiple vlans on CE modem,
without adding bridge in interface and in bridge port aslo
its possible if i add bridge in interface and in bridge port i add vlan & ether
here i hope to configure the same without bridge ( client modem as routing mode)
