There are 500 - 3000 Clients in our network (no wireless), each client should get its own vlan.
Ip and MAC are not static, so a client can interchange to other.
No client should be able to communicate with others without passing the gateway. (mac-communication should be only able to Gateway, no others)
the process:
the client send a dhcp-discover in its own vlan
the gateway dhcp-server gives an direct internet-ip from pool to client (no masquerading)
the gateway should pass-through the traffic form vlanX to internet and backwards
1.-2. can solved by setting a DHCP-Server-Interface to every vlan (maybe someone get a better solution)
My question is:
How can i pass-trough (route) the traffic from 10.10.0.3 to 10.10.1.1 and backwards.
I know the packet have to mangle and set to IP->Routes. But i don’t how and it should work for every vlan separately.
MFG NukeLE
EDIT: There are a RouterOS (x86) L4, L6 and a RouterBOARD 750 available. There is no Cloud-Router available.
Well, depends on the setup but you will need more gear and more than anything capable gear. running 500 to 3000 VLANs you might end up having MTU problems. What you have here it’s a real challenge considering the equipment available!
The l2mtu will be automatically reduct.
VLAN only need 4 byte at all. So theres no problem whit the mtu. I prefer a solution for x86 RouterOS. Maybe if there is no, i will look for a cloud router.
Whatever you might think is best.
My personal opinion: talking about VLANS on MKTK and the amount you want… on a double thought I wouldn’t really go for MKTK gear… you’ll grow old configuring VLANS, trunks and access ports
Anyway, in networking there are many solutions for a problem and they all work… depends on each administrator what considers best to pick.
